j par
Well-hung Member
Well I don't let things go very easily so I'll be clouning you guys endlessly when this thing purse like a kitten, or not.
Anyways, going at it full bore tomorrow. I'll goop the intake manifold on, the fuel pump, and water neck. I'll gut an old thermostat. I have to string it up to finish cleaning the back of the motor and install the two freeze plugs. Maybe get alternator brackets sorted, water pump finally gooped on. Get an idea of how the pulleys will (or will not) line up? Hopefully I can get some primer on it?
