I would, just saying......
You can't beat this logic!Well, here's the thing......it will take just as long 400 miles from now to put it in as it will not, less 1/2 hour to drain and pull the rad. So run it, see if it leaks, if not, then...................
Burn!It could be worse, you could have broke a tap off in a hole?
