I know, sneak some Bosch EFI injectors in the holes and have a running, idling intake. Thats bad ***.
PS>> how do you water cool with that beast?
Mounting holes have been modified for some other head.... W5s? W2 square port?
Those are way cool!
I should not give you credit because of your horrid spelling, LOL, it's "Hilborn"
I Knew it wasn't correct while I was tying , it just didn't look right . Every one knew what I was trying to say.
4 naked girls doing a hand stand and the splits at the same time....![]()
Mbaird, as far as I know, the W2 was allways an oval port but could be made into a rectangle if desired.
Assuming I live that long LOL this will be EFI. Looks like it has the barrel valve, unless this is just a distro block
That's a barrel valve. There should be a number on it. Can you post it?
I don't have "it" yet. Photos came from the seller
so what you are telling me, is if i keep a close eye on your front porch i can have one of these?I don't have "it" yet. Photos came from the seller
Do you need a barrel valve? That is part of it I won't be using
But Bernie told me I deserve itThat porch will be well guarded LMAO
