mopar head
No one ever put a chev in a yak?Pontiac never made a 307.
I would try to find stock/different distributor for sake of trouble shoot. (if possible)
If aftermarket HEI distributor, Ive had new ones being junk more than once........
D.
He said he buggered it up somehow. How? dunnoNo reason he can't drop the stock dist. back in...........
So did I, not a fan either. Now have a killer Die Hard. Last Diehard lasted my 10 years and it was still good when I replaced it.Btw, i had an optima battery once. Not a fan.
https://butlerperformance.com/rt-5038-the-pontiac-engine.htmlPontiac never made a 307.
Correct, by the late 70s or a bit earlier, they were kind of sharing, b-o-p , buick olds pontiac,
Your fire chicken of that era could of had a just about any thing, 403 olds, 455 pontiac, 400 pontiac, its confusing...
What is a yak?
That`s the only reason I was asking just incase the op was placing the firing order in the wrong rotation and cause havoc. Just trying to help the OP. I`ve read chev based engine.Pay attention to the little asterisk. See where it says the distributor rotates clockwise? You know why? Because the 307 was not a Pontiac engine. It was an Oldsmobile engine sold in Pontiacs. Pontiac never made a 307.
Anywho , strange it ran great before he did all that work, seems timing related to me.
Good luck OP
The engine in the photos clearly is a Poncho unit. Poncho dizzys spin counterclockwise.................No one ever put a chev in a yak?
