skrews
Had this intake for a number of years, but could never bring myself to try it. I like the tall swept runner design, but I hated the hermaphrodite spread bore square bore carb flange deal, not to mention the terrible transition from the carb flange to the plenum.
When Jim LaRoy posted that beautifully reworked Strip Dominator it inspired me to rework mine.
Instead of milling down the carb flange and building a plate like Jim I took the easy although not as trick route and welded up the carb flange.
Next I milled out the plenum and carb flange.
Coming along nicely. You can see the tremendous difference from the finished side vs the unfinished side.
Will post more as I finish up.
