I'm looking to buy or duplicate a 1967 Dart drive shaft for 273 4V and 8 3/4 OE application.
What I have deduced.
1. It used small U-Joints on both ends.
2. It is the same length regardless of transmission (3 spd, 4 spd or automatic)
3. it measures 52.58 cL to cL from shop manual (I have seen one parts book that listed it at ~52.25)
4. It is 3 in dia
5. I assume it is turned down on the pinion end, not sure about the transmission end
6. The 68 & 69 use large u joints both ends
If anyone has an original unmodified 67 Dart that was equiped with HP 273 4V with 8 3/4, I would appreciate a photo of the drive shaft at the trans end and at the pinion end.
Thanks
4. It is 3 in dia
Thanks
