mopars4life
Picked up a 73 dart sport 340 4 speed convertriple car that had been hit while parked in the late 80s and left to sit. It is also an ac and rear defrost (with the grids), light package car. It was Fe5 red with a black bucket interior but had been redone into a show car at the time with custom paint and lift off hood. Had a full white vinyl top. The body is real rough on it. Would need drivers frame rail from accident, patch on pass rear frame rail, floors and trunk floor and extensions and quarters. Wheel well on drivers side as well. Would also need rocker patches and the bolt on panels up front (donor car would be the only way to go). Front subframe is good with a patch or two needed but the vinyl top killed the roof. Pretty rare with the convertriple option and 4 speed and AC. Has a posi 8 1/4 rear. Can't bring myself to part it out so I think it will just sit under a cover. The car is complete and looks to only have about 78k on it and motor was built and is not locked. I know it probably isn't worth saving but the combination makes it pretty rare. Just seeing what other members though. BTW no fender tag and can't find a build sheet for it yet.
