i love that blue
i love that blue
Do disjust scored a pretty good deal on shifter cables for a PB 727. 25 bucks plus shipping. in good shape it appears too. Usually they go for WAY more
the push button cables are actually self lubricating via the ATF fluid from the trans but I will use that on my Grizzly throttle cable, it stuck and i rolled it last fall. Usually when the PB cables go bad, its from the cable insulation cracking and leaking the fluid or it got to close to the exhaust and melted, thus leaking.Do dis
Houseboat Control Cables - How to Lubricate, or Save a Throttle Shift Cable
I have used this method in sticking atv brake cables. Works very well
I charge an hourly rate of $75 in my shop here.... Lowest repair shop in the county is $100.......Great. Now i’m hungry....
Had to go rescue the local boat repair guy- again.
His “mechanic”
Was replacing a distributor cap on an inboard.
Marked wires wrong. #1 was one tower off.
Took a littke bit to figure out the mistake.
Dude needs to find another line of work.
Seems like i fix more for free in less time.
Owner wants me to work for him in the worst way.
50/hr i might consider it.
come fix my durango's AC, its one of them new special AC systems where you can't simply charge itI charge an hourly rate of $75 in my shop here.... Lowest repair shop in the county is $100.......
wait WHAT?! whereGeez, up to 45% tax credits for electrical solar panels.
Sorry, thinking out loud after seeing a commercial for a local HVAC company.wait WHAT?! where
Got near 7 grand tax credit on my solar install.Sorry, thinking out loud after seeing a commercial for a local HVAC company. View attachment 1715187095
70/hour. Im hapy to have the lowest shop rate.I charge an hourly rate of $75 in my shop here.... Lowest repair shop in the county is $100.......
Easy to do. Low overhead is a plus!70/hour. Im hapy to have the lowest shop rate.
I need to bill 1.5 hours/day to keep up with overhead and payments.
Damn, and yur way out there in Cananda... Maybe I should go up ??? LOL70/hour. Im hapy to have the lowest shop rate.
That's the way to do it.Tiny shop, easy to heat and its at home.
My parts profit basically keeps me in fuel and shop supplies.
I dont overload myself with work as i dont want the stress. Like mitch, i select/deselect my customers as necessary.
That's a lot of water in a short amount of time.Estimates are 5-6 inches of rain in 35 minutes. It has never flooded here before.
Correct.Question on Trailer Tire pressure.
I just installed new tires on our travel trailer last year. I checked the pressure today and it was at 55lbs (max cold is 65lbs). I should keep them inflated to 65lbs correct?
