I did, no snow here but plenty of other weather to contend with...Good Tim...I was going to suggest that...You saw what I did with mine......
I was thinking more about, keeping it out of sight....I did, no snow here but plenty of other weather to contend with...
down at my moms house at the moment.Hows the weather in Laurel ???
Thats probably good....Raining here a lot, probably at your place as well...down at my moms house at the moment.
Really?Thats probably good....Raining here a lot, probably at your place as well...
Still raining here...Really?
Overcast, but nice here.
nothing wrong with a little rainStill raining here...
Have a New Perfect circle pump if needed.Best source for a new oil pump and pick up tube for my LA 360 oil pan , if I remember right it is a 392 pan by Milodon
nothing wrong with a little Rani
Why is it a Circle ???I
so that 75 duster I was trying to get ahold of …….I offered the guy 4Gs
Because it is PERFECT!Why is it a Circle ???
that sucksso that 75 duster I was trying to get ahold of …….I offered the guy 4Gs
turns out it wasn't a 318 car as I thought, but rather a factory 360 car.
It has buckets and console and is a factory L code 360 duster ….quite rare
The old guy bought it new and didn't really want to sell so he told me he would sell for 15K and the car is for sure not worth that but he obviously doesn't want to sell so that is over with
Would have to be REALLY nice for that money.so that 75 duster I was trying to get ahold of …….I offered the guy 4Gs
I have only used one a couple of times. So not really enough time to make a fair assumption or enough time for me to get a handle on the technique. I use a stud gun with a shrinking tip and a rag with water if I really need to shrink. I can see where they would be useful on thicker gauge to warm up a larger area and work it.@GeorgeH ,have you ever used a shrinking disc on a grinder? I see a lot of videos,guys say they work well.
If that's the case I really overpaid for my Swinger! LOLWould have to be REALLY nice for that money.
Just like Ben!Because it is PERFECT!
Pick up tube is $16.00 at O'Rilles, , Standard volume pump is $46 bucksYou can get oil pumps and pick up tubes at Mancini Racing...
I've also bought pick up tubes at my local NAPA for $20....
I like high volume high pressure oil pumps... If you get a Melling oil pump, they come with a 72 psi spring... The MP ones are lower pressure stock (around 55-65 psi) , but you can get a high pressure spring to bring it up to 75 psi... But if you buy the Melling HV pump, it comes standard with the 72 psi spring...
MP Pump:
Mopar Performance High Performance Oil Pump
Melling standard volume:
Melling Oil Pump
Melling HV pump:
Melling High-Volume Oil Pump
Pick up tube:
Mopar Performance Oil Pickup, 3/8" Pipe
