dartfreak75
Restore it, Dont part it!
That is the one that has to be burnished correct? Do you happen to know the press and go part #?Remove the bushing.. the hot tanking will probably ruin it anyway.
PN P1737725 Mopar Performance
And heavy duty intermediate shaft P3690715.... another 'good-too-replace' part to go along with the new oil pump. Sometimes the old shafts get the corners worn on the hex end and can turn in the pump hex under high loads. When that happens, oil pressure drops or goes to 0.
