Hemidale426
- Joined
- Feb 14, 2008
- Messages
- 45
- Reaction score
- 3
Has anybody else having problems with hyd. lifters?
Thanks -going to pull them this afternoon and take a lookNot myself, but reading quite a few have had issues. I dont believe comp as much as Hughes I believe.
Thanks and good luck with yours.Yes. Never had any problems before.Just did a 318 and had 4 fail by not pumping up.Took them out,pulled apart and cleaned, re-installed only to fail again. Replaced all with Lunati's that have the snap ring instead of wire for the plunger. Haven't started it up yet.Fingers crossed.
Thanksneither comp or hughes makes lifters
there are really only two choices
and only one for retrofits
(info may have changed)
Guess I should be glad I got it done in 2004, maybe I got some of the last good ones, out of the last good batch,lol.They've been spinning well to 7000 and beyondBeen having, and hearing of, poor hydraulic lifter quality for maybe 10+ years now.
Depends on the block, the cam lift and how tall the lifter bore is... I like the no oil band solids so it matters not the height of the lifter bore or the lift of the cam.I should of taken photos. The Comp and Lunati look way different in placement of the oil band. The Lunati had 2 bands,one wide and a narrow band. A friend told me that he had problems with a 2nd gen Hemi and found that there is a difference between big,small and Hemi block hydraulic lifters. Apparently the one size fits all doesn't always hold true.
If it was only the lifter that was damaged, it wouldn't be such a big deal. But when the lifters fail, so mush expensive collateral damage is done. That's what sucks...Wow, this is disheartening that we have to have problems like this.
Agree, but we shouldn't even have these issues. We didn't used to, we pay good money and expect a good product. Now it seems like some failure is acceptable and ignored by the companies.If it was only the lifter that was damaged, it wouldn't be such a big deal. But when the lifters fail, so mush expensive collateral damage is done. That's what sucks...
I have had several hydraulic lifter failures, most recent with a set of Comp retrofit hydraulic rollers.Not myself, but reading quite a few have had issues. I dont believe comp as much as Hughes I believe.
I am done no more hydraulic anything on a cam.
