Underground meth lab?How many levels of old streets are there?? Looks like a layer of bricks under the dirt??
Good Morning
? Standard Torx, Torx+ (both come in tamper proof) and 5 star. There are some new Torx bits out that can be used on rounded Torx fasteners.@toolmanmike would you happen to know what the difference between a standard Torx bit and a Removal Torx bit is?
Yep!Damn toyotas.
Oil fiter cartridge is in a plastic cap. Need a special wrench to change it. Filter comes with a little spout to drain oil,every time i try it i break the spout.
Filter was so tight i thought i was going to break the cap. What a pain in the butt.
On to intake gaskets in the poly.
I have a large 'Channellock' type pliers. Good quality and even the same blue, but says JC Penney.I never knew JC Penney marketed a socket set.
I found a socket set that has to be very old.
Who woulda thought
Yehhhh…. So what do those gold plated beauties go for? lolwell, my wallet is MUCH lighter now. Just ordered a Snap on T40 set. Comes with the Regular Bit, the Torx Plus bit and a T40 removal bit(I called and apparently the Removal bit is coated in diamonds and has a tighter tolerance to help with stuck and rusty torx bolts)
47.50 a pieceYehhhh…. So what do those gold plated beauties go for? lol
and they aren't even sockets, but BITSYehhhh…. So what do those gold plated beauties go for? lol
No brainer to me. 60’s beats 80ish anytime!Modifieds in Bako tonight where it will be 80ish at race time?
Or Sprints in Ventura Saturday where it will be 60ish at race time?
Decisions decisions
So, that's for a 3 bit set at least? Them are some special snap on industrial grade diamonds it the one ya know.... Could probably pop one out and have it mounted in a ring.and they aren't even sockets, but BITS
What can you get for two balls????
No. Each bit is 47.50!So, that's for a 3 bit set at least? Them are some special snap on industrial grade diamonds it the one ya know.... Could probably pop one out and have it mounted in a ring.
Well, I've broken 3 of the damn T40s already, 2 harbor freights and 1 Husky Brand. These damn bolts are locked in TIGHT!That's crazy stuff right there. No way I would pay that for one use.
yeah, the HF, just instantly twistHF are guaranteed also. Try heat yet an kroil?
Yep, it would. I've tried some heat to no avail. Factory puts a high temp epoxy on the threads that is resistant to oils...Would really suck breaking the head off. Sounds like the threads are locked in tight no bit will help that till they are loosened somehow.
What are you trying to get loose?
