MomsDuster
I still like the old school impact driver idea!
I'm highly considering the latter should these bits not do it.
gonna smoke it afterwards?Ok, time to change the blade on the lawn mower and cut some grass...
Hmm, my torch is just a propane plumbers torch. Didn't want to risk it with the Oxy/Ac torch.Heat the bolt. I use straight mapp gas in my propane torch, its hotter. It takes a lot if its in aluminnium.
I remember my buddy breaking 3 wrenches trying to get 12mm 12 point bolts off his yoke to pull driveshaft. Didnt think heat would help. Like butter..that locking compound melted easy.
Quick!? Need to have you show how that's done!Well done with a quick coat of wax. Thought it was getting warm so came in and checked.
Its 73 degrees, with 67 dew point, and 81% humidity...no wonder I was working up a sweat!!
Not sure but not a lot. The Baltimore Pike was built early 1800s but the alignment might have been a little bit upstream as appaerntly there was a bridge. I think we're seeing reinfocement to spread the loads under the track bed and street.How many levels of old streets are there?? Looks like a layer of bricks under the dirt??
How’s the headache?Its too hot in my office. Im going back to work.
Gone..How’s the headache?
No brainer to me. 60’s beats 80ish anytime!
They free or rusted to it?
One factor to be considered in the decision. The percentage of outer wear on the female spectators.![]()
a screw driver?View attachment 1715346138
and a ball peen? Worked on 40 year old Brit bikes and those soft Phillips screws on side cases.
Well, that is a valid point. But if I’m going to the track it’s not for the women, I’m going for a fix of race fumes!One factor to be considered in the decision. The percentage of outer wear on the female spectators.![]()
Yikes!Went and looked at a guys old Ford Truck at his Tree Nursury . Said the gas pedal wouldn't mash. Lol. Nothing wrong with the cable, but the primary shaft on the Holley 4 V was locked up. He says. Oh yeah. It's been sitting here for three years...
View attachment 1715346153 View attachment 1715346154 View attachment 1715346155
That’s just nuckin futz whackadoodle bat **** crazy! Even for strap on!No. Each bit is 47.50!
