Are you handy with this kind of stuff? Do you have a garage/shop with a wire feed welder, grinders and the like? If not you need to find help.View attachment 1715379062 View attachment 1715379063 View attachment 1715379064 View attachment 1715379065 View attachment 1715379066 Ok so there's after I pulled the old ugly sundried vinyl top off, I found a few holes around the back glass on my swinger and I'm a little confused on what to do here. The window leaks through the holes obviously but also around the bottom left corner of the window. I want to take out the glass, patch everything up nice, get a new seal, trim clips and then throw a vinyl top on but i'm not sure how to go about it or if I even should. At this point the trim is out but the clips are mostly bent or broken.
2 man job to be safe. Easier to call the glass company. We have a couple guys in town that work at the glass company that are into cars. They will come over for a 12 box of beer and pull glass.I knew I couldn’t avoid removing the glass. I don’t weld but how hard is it to take out the glass and reinstall it(assuming everything is patched up and fixed).
I agree with this no need to cut up a parts car that is fixable without ruining another car.Cut the old out and weld good in.
Nice quality work there Sir.Here are some pics from when I did mine. Both sides were bad on my car. I used those patch panels linked above and fabbed up the rest.
