nm9stheham
Funny you should ask that.... I checked on a 675 head. With a 0.039" head gasket, the valve movement with my simulated 2.02" valve head was about .255" when it contacted the block.If a larger than stock intake valve is installed in a stock 273 head....... what’s the lift point at which the valve contacts top of a 273 block?
I've run through all the details with trying to use a cam at around .520" actual valve lift.
