Anyone ever run Speedmaster Heads on their small blocks
I think they got there pic mest up on the shocker sight.
If you click on the picture and then read at the bottom the closed camber said FORD and the open chamber says BB mopar.
Are you saying that because of the 185cc intake chamber???
Agree.
the combustion chamber look bigger on Shocker but claims to have 65cc like the SM's How ever the ported SM" have 68cc aka the chamber needs some work!?>.!!
Is there flow number out there for the shocker?
Claims 285 but is there a full lift swing of the port somewheres?
CNC Shocker 185
Flow Data @ 28″ water
lift 200 300 400 500 600 700
Int 142 202 251 278 284 286
Ext 124 159 190 203 219 231
Not to bad IMO. I’m sure they can be improved.
And the SM site has no flow numbers
I am going to try to order a set of bare heads tomorrow. If I get a set I will put a set of my Edelbrock valves in them and flow test them. I will then port one intake port and give flow numbers after several mods. Valve job, Open pinch, straighten common wall, chamber work, short side widening, etc. I will also post some air speed numbers
YOU THE MAN!
Air speed number will be GREAT, and thank you in advance!
What head do these flow number belong to?
Thanks man! Pictures included?
Seriously, I appreciate this effort very much.
You are doing a huge service for the community here at the board. Thank you very much.
Needless to say extremely interested...
Of course PRH just posted numbers 4 unported heads on one of the other three threads that's going on these heads right now... :BangHead:..
:drama:...
:drama:...
I'm confused, maybe, but I think those #'s are for the CNC ported SM's posted by another member, I think. lol
Nice!. I was thinking of getting a bare set of non cnc heads to see what they could be become on a budget-is that what you are doing or are you getting the cnc?
