I now know about the 360 in the Blue Mutt since I have removed the heads. I confirmed the pistons are the older TRW 11.5-1 and I have some factory "J" heads with the 2.02 valves. I don't really have the means (or knowledge) to determine where the motor is for final compression. Any thoughts where it may be? I tried looking at some different calculators but can't seem to find all the specific info to input for the calculations. Below is what I have
360 block - bored .030 over for the 11.5-1 pistons
stock stroke
Stock J heads - no work on combustion chambers
will use felpro gasket - compressed thickness listed .049-.059 with 4.180 bore
haven't found the dome volume or piston deck volume - these seem to be what I am missing for the online calculators.
using the Lunati Voodoo cam 10200702, hoping I haven't moved into race gas with this thing
stock stroke
