Based on the video and my calculations, the Mopar small block RPM potential would be 9,000 RPM.
86mm is 3.386 inches, so a lil more than the standard 3.315 SBM stroke; but not quite as much as a 3.58 from a 360..I've never owned an engine with an 86mm bore or stroke
Some flaws I see in the video...
It's hard to keep torque constant... Longer stroke will give more torque - that's the definition of torque...
Torque would be somewhat constant, even though longer stroke has more multiplying effect over shorter stroke. But smaller bore will have less surface area so less pounds per square inch being applied to the crank to be multiplied.
Torque has more to do with displacement than how that displacement is constructed eg.. bore and stroke.
For power, engines with similar displacement the bigger bore will have more advantage than longer stroke.
No, stroke directly affects torque by the definition of torque... Force times perpendicular distance... The longer the stroke, the more the perpendicular distance, hence the more torque...
Just like using a pry bar - the longer the pry bar, the more torque it produces...
But the funny thing is, the engine masters video refutes that. The short stroke BBM made more torque over a broader span than the long stroke Chevy.
I was surprised.
Yes but your not accounting a smaller pistons is gonna have less force against the longer stroke than a larger piston against shorter stroke.
Stroke is only one part of the equation.
Eg.. A weak man with a longer pry bar vs a strong man with a shorter pry bar could be made to be even depending on the lengths.
I was surprised.
I was surprised.
2.1
Captain 'know it all' alert.
Don't bother Rob he never admits when he's wrong , it's a life of denial.
Just throwin **** out there....you need to compare on identical engines, not mopar vs chevy, there are too many other variables that can play into the results...
Yes, it the bore affects how well the mixture burns, but if the mixture can burn properly more stroke will give you more torque...
. The same heads between two engines.....the shorter stroke will act as if it has bigger heads.An example is the 440 six pack vs the 426 Hemi... Both engines were rated at 495 ft*lbs of torque and has the same stroke... If bore had more influence on torque why wasn't the 440 putting out more torque???
It is a far comparison based on cubic inches only.
I would love to run into enough money to throw away on your very cool idea. And try various cams, heads, etc....
340 vs 360 showdown shoot out!!!
Screw it, while I’m day dreaming of screwing off with my mega millions win fall, I might as well include a 408.
You do realize 426 is a shorter stroke and smaller bore than a 440 right? And the 426 couldn't beat the 440 until you gave her enough gear to rev ...so here you go ,shorter stroke reving higher will beat the long stroke bigger bore.
That's a couple things way better heads and RPM...
however... The same heads between two engines.....the shorter stroke will act as if it has bigger heads.
