Just buy the cnc ported ones.
A set of 360-2 cnc230’s, the matching intake, and a set T&D rockers should be a great head start on making enough power where the integrity of the stock block might start to be a concern.
I can’t see any way it’s worth the $$$ “overall cost” to get into a Victor headed build unless you’re going to use an aftermarket block........ and you’re looking to make at least around 700hp.
If that’s what you’re looking for ....... make sure the check book is well stocked.
Don’t get me wrong...... those Victor heads can really make some power with the proper work done to them.
Just depends on how deep you want to get into it.
How I like to go about it is....... pick the power level you’re after.
Then the path/choices get clearer.
I don’t like building time bombs, so as an example....... if someone comes to me and says they want 800hp...... then the conversation starts with, “you need a block”.
If they’re looking for 600-ish out of a SB and want to use a stock block..... then we have the “as long as you understand it will likely have a finite lifespan” talk.
