72blunblu,if you are talking about the moog k7040, i just got 2 sets off ebay.
I'm
NOT talking about the K7040's, I'm talking about the K7068's. The K7040's are readily available everywhere but they do not fit the later '73-'76 strut rods.
Like many on this site they must not like you. Check the dates I can get what ever I want. I never posted the PN before because I never kept the boxes. But I ordered these not because I needed them. I just was sick of your bullshit. Note I got 2 for 67-72 a bodies and one set for 73-76 A-bodies. They are available for commercial in store on the east coast where I live. I can get as many as I want. Both sets have shear sleeves. Not like the poly bushings that were praised by you in the past several times. You just can't stand eating your words.
Wait until I get a car on the lift with poly LCA's and show how bad they are. You'll eat your words on that also.
I ordered three more sets of each for freinds. And I need a set for the 440+6 Cuda we have here. They'll be here by Friday. Wow you really sling the **** to prove your not wrong when you should just admit you never ordered nothing. Why would you? Your poly style are working just fine for over 10 years. LMFAO
Well, that's not what my local Napa told me, and using the K7068 on NapaOnline takes you to the single piece bushing which is incorrect for the '73-'76 strut rods. So congratulations on getting a set of K7068's, but I did what you suggested and I can't control what my local Napa says.
And my Jeg's order is still on backorder, placed 7/17.
So is my Amazon order from 7/27.
As far as the poly bushings go,
I don't use poly strut rod bushings. I have also never recommended that anyone use them. EVER. Not in any of my 10,848 posts, not once. Let me repeat that, since apparently you didn't comprehend what I said back in post #29.
I HAVE NEVER USED POLY STRUT ROD BUSHINGS OR RECOMMENDED THEM TO ANYONE.
I use adjustable strut rods on all of my cars, and I recommend adjustable strut rods to everyone else. I have also occasionally recommended rubber strut rod bushings for those that insist on using rubber LCA bushings. The poly strut rod bushings can cause issues, like I've already described in this thread in post #29. Why you keep saying I used poly strut rod bushings I don't know, other than you just keep confusing LCA bushings and strut rod bushings.
I
have used poly LCA bushings. And I will continue to. And I will continue to recommend them, because it's easy to explain to a rational person how they're different from rubber LCA bushings and why they still work. Unfortunately, you don't seem to be a rational person.
As for your video, I eagerly await it. I literally can not wait. Video evidence of what you're doing wrong will be priceless. Although if your video is as blurry as the pictures of your invoices it won't be of much use.
