You can't "guarantee" nothing... That's just your opinion...They are stuck with those carbs as they have no choice. Given the option between what the rule book says is legal and what ever carb their heart desires, I guarantee most if not all would be running something else. Likely a Holley.
While I agree the problem is there's too much monkey see monkey do and everybody has to have a holley and 90% of the people don't know how to adjust them. When an Edelbrock would serve them much much better...It may be his opinion...... but it’s apparently shared with most of the racing and hot rodding world.
In situations where people can run whatever carb they desire, the overwhelming choice is to use the Holley or Holley style carbs.
I guess a good question would be what percentage of your customers or people that you know that have a holley shouldn't have one LOL..It may be his opinion...... but it’s apparently shared with most of the racing and hot rodding world.
let me see if I can beat anybody to the punch here that's going to say they've had their Holley carburetor forever and never replace the seal...
Please point me towards which currently available Edelbrock/Carter carb would be suitable for a 650hp+ hot street/strip or bracket race engine with a cam that’s got over [email protected] duration in a single carb application.
I want one that doesn’t require reengineering all the circuits so it will idle in gear and also provide adequate fuel flow capacity for the 650hp+.
Well I have to agree as well but do you think 25000 out of the 50,000 members of this forum have a cam like that or an engine with that much horsepower?..Please point me towards which currently available Edelbrock/Carter carb would be suitable for a 650hp+ hot street/strip or bracket race engine with a cam that’s got over [email protected] duration in a single carb application.
I wasn't sure if I should have given you a like or an agree on this post but both apply. Again making my point though... I've got a customer right now that has a brand new EFI setup still sitting in the box for The last 5 years brand new unopened. well it is open now because I had to open it up and check it all out. of course it doesn't come with the fuel pump and all the other accommodating parts. I think he got it as a gift from his kids and it was well I can't even tell you how much. But I'm trying to talk him into a simple $300 Edelbrock because not only does he not know anything about EFI the expanse I'm getting the rest of the accommodating parts I'm getting it all up and operating will be much more... But again it's to make it so they don't have to do anything. But come to find out there's a lot to do to make one of those run.I don’t care if it “can” be tuned for that application.
It’s certainly not going to just be a matter of swapping the rods and jets.
Most of the people I deal with just want to buy something and bolt it on....... and have it at least be “close”.
I’d say at least 50% of the builds I’m involved with are that type of that [email protected] combo....... or rowdier.
Then probably close to 1/2 of the remaining customers are doing something with a 6bbl set up.
More and more of the customers with the milder combos are going to EFI.
And one more thing (columbo would be proud) do you agree with the original post that all Edelbrocks should be put out and smash with a hammer?..I don’t care if it “can” be tuned for that application.
FYI.. I had one of these 260 + cams last cam.. I didn't think 119 miles an hour in a quarter mile was too bad for a Edelbrock and a carter performance paired together... One that came with the car on its 318 and one that was given to me as scrap metal... Neither one gave me absolutely any problem for all the years I had them. I sold them for $150 each and hope they continue to work as they did for me...I don’t care if it “can” be tuned for that application.
I believe your 4 speed masked some of the low speed transition problems of the Carter.FYI.. I had one of these 260 + cams last cam.. I didn't think 119 miles an hour in a quarter mile was too bad for a Edelbrock and a carter performance paired together... One that came with the car on its 318 and one that was given to me as scrap metal... Neither one gave me absolutely any problem for all the years I had them. I sold them for $150 each and hope they continue to work as they did for me...
You were limited by the cylinder heads. that is all.Another beating to the punch if you had Holley it would have went faster LOL...
I had a lot of bad things going on with my combination..You were limited by the cylinder heads. that is all.
4sp ? auto?I'm waay over 650hp with a single Carter/Edelbrock style carb, currently a clone 9635SA 625cfm. Helps when a large percentage of the overall mixture ends up coming in under the throttle body
Wouldn't change it for the world at this point, easier to get races with it and I love the looks I get when I show someone what's under the air cleaner. Over the years I've tried just about every modification/calibration while tuning with a wide band, current calibration isn't far from out of the box.
Grant
For you...camshaft 250 or so @.050, single plane and auto trans is tunable nightmare for a Carter style carb. period !
