Quick question these don't require sealant, correct?
I would put a thin coat of Permatex on them.
25-30 foot pounds IIRC, follow manufacturer instructions!Thanks, what do you guys torque the thermostat housing to, on an aluminum manifold?
agree, and thin bead of sealant on "dry" sideI sue the ones that are already sticky on one side to hold the thermostat in.
I like the PermatexNobody for a light smear of Hylomar, or the easier-to-obtain Permatex equivalent?
And the safe thing to use on aluminum intakes is studs instead of bolts. Many used aluminum intakes have stripped tstat threads because of the use of bolts.
One of the many things I like about B/RB engines is the "dry" intake manifold It never hurts.Assuming you have a small-block of courseOne of the many things I like about B/RB engines is the "dry" intake manifold
Although I do have an aluminum WP housing, so I should put studs in it too. Thanks for the suggestion.
No, never had a leak either.Quick question these don't require sealant, correct?
I torque to 120 inch lbs.Thanks, what do you guys torque the thermostat housing to, on an aluminum manifold?
Some owners will throw the coolant and possibly coolant pressure at it without allowing time for the RTV or whatever to cure. Some have opted for something other than Felpro. I too went ahead and bought one of these to have on hand next time I have to replace the thermostat...
Thermostat Housing Gasket - Silicone Gaskets - Real Gaskets Tennessee
Be careful torqueing 30 ft lbs on those aluminum threads.I read above , nice to know. Thanks
