Fel Pro thermostat gaskets?
coalman
Texas
Quick question these don't require sealant, correct?
I would put a thin coat of Permatex on them.
Hello Coalman,
I Just as Sireland67 stated I also apply a very small amount of Permatex "Ultra Gray" (my choice) by wiping both sides of the gasket with my finger to just have a skim coat on it. Really helps if you have to remove the gasket in the future it will come off with little or no effort.
Stay safe...
Happy Mopar :)
Arron.
Thanks for your input, I called Fel Pro, on the blue gaskets, not required if surfaces are in good shape, yes if not.
I always do. I glue the gasket to the t stat housing usually with Indian Head gasket shellac but not the intake. SOme use 3M weatherstrip adhesive. That's a little harder to get off next time. The reasons why I seal to the thermostat housing, #1 The intake surface is machined and the tstat housing isn't. #2 You can take the tstat housing off the hose and clean the gasket off with the wire wheel. Scrape off what you can.
I sue the ones that are already sticky on one side to hold the thermostat in.
Thanks, what do you guys torque the thermostat housing to, on an aluminum manifold?
Not quite the same - Hylomar is a solvent-based non hardening blue goop. The nearest locally available Permatex equivalent is #85420 "Fuel Resistant Gasket Dressing & Sealer". Smells and looks identical to genuine Hylomar.
If you really want silicone, you can also use their #22071"Waterpump & Thermostat Housing RTV Silicone Gasket Maker"... definitely coolant resistant ;)
Thermostat housings can be a problem
"Back in the day" when housings were good, machined, heavy cast iron, there WAS no problem
Then "Cal China Chrome Custom" came along. And OEM alloy housings. And those silly stamped steel ones
As stated above, always check for flatness
Be careful not to overtighten so as not to warp the housing
Don't use ANY sealer that will act as a lubricant 'slime' and allow the gasket to waltz out of place
Don't overtighten
Be careful you do not overtighten
Be VERY careful not to overtighten
Before you go any further take a flat steel ruler and make sure surface is flat. If not go and buy a cast housing, usually a local speed shop will have a good one. Any bow in the surface and you'll never seal it.
And the safe thing to use on aluminum intakes is studs instead of bolts. Many used aluminum intakes have stripped tstat threads because of the use of bolts.
Assuming you have a small-block of course :poke: One of the many things I like about B/RB engines is the "dry" intake manifold :)
Although I do have an aluminum WP housing, so I should put studs in it too. Thanks for the suggestion.
It never hurts.
No, never had a leak either.
I installed today 30 foot lbs, Edelbrock Air Gap, no sealant will see what happens.
Thanks to everyone!
