ChargedDart75
You and me both.But I'm VERY thankful for WHERE I am. I like what I'm doing and how I'm doing it. I wouldn't trade it for anything.
My hat is off to you guys who take long trips in classic cars. I know they can do it, but I would be too paranoid about something happening to the car along the way. I have other cars for things like long trips.
No one ever took long trips or drove cross country before EFI. Just didn’t happen. Unreal.
We built the inside of our '77 Shorty Van just for traveling. Full size bed in the back, some electrical if we have a place to plug in... I love van'n...My hat is off to you guys who take long trips in classic cars. I know they can do it, but I would be too paranoid about something happening to the car along the way. I have other cars for things like long trips.
We built the inside of our '77 Shorty Van just for traveling. Full size bed in the back, some electrical if we have a place to plug in... I love van'n...![]()
We don't know want you're going to do in your shaggin wagon. lolWe built the inside of our '77 Shorty Van just for traveling. Full size bed in the back, some electrical if we have a place to plug in... I love van'n...![]()
Get a dual quad intake and run both.You're drifting, boys. What should I put in my 408 inch small block. Sniper, or my QF 750 on an RPM airgap. 10:1 solid roller camshaft, with the TF 190's. Kicking the anthill.
Just had to chime in.... you are the one who made the statement about someone saying you said something you didn't yet here you are.... perhaps your reading comprehension skills are challenged so I will clarify my statement; in modern times such as now my classic cars are worth much more than they were back in the day, therefore I would would not want to risk them on a long trip. But you know exactly what I am talking about but your inner dick just has to be heard.![]()
10k for EFI ???? Count this poor boy out... LOL
Eat'n, sleep'n, and sit down in your chair and get ready for this......We don't know want you're going to do in your shaggin wagon. lol
Truer words have not been spokenOnly you can make that decision. IMO you should do the EFI but ONLY IF you are 100% committed to learning it. In fact, no matter what you chose you should be 100% committed to learning it.
IF you absolutely have to have it so you can hit the key and have it idle like a new car than it’s EFI. If you don’t mind spending 60 seconds before dropping the car into gear than the carb will work.
IF you don’t like to get fuel on your hands then it’s EFI. If you hate wiring (God knows I hate it) and routing all that crap then maybe EFI isn’t for you.
IF you are willing to pull the distributor several times to finish the advance curve (you should also be using a vacuum advance if at all possible) and learn how the distributor and carb either work together or hate each other...than carb. If not, than EFI.
It doesn’t really matter what you chose. It matters what effort you are willing to put into it.
It will be a Holley HP system with a dual sync distributor. So sequential port injection and timing control as well as some limited data logging. It is drag race only application with a short exhaust system so I'll have it open loop up until 2000 rpm and then go closed loop. The car runs down the track between 5000 and 7500 so it should run okay. Might take some work to get it to run clean on the two step and to launch hard but I'm not worried about WOT. We'll see how it goes. I've tuned 8 stacks before but not this Hilborn setup. The Hilborn setup is brand new so who knows what we'll run into.@AndyF what ecu are you going to use to control it? I’ve tuned a stack efi on a 555 bbc and to say it was a bear is an understatement.
The one I did I had to tune it in throttle position only. I had to get away from map. The rate of change in the map sensor was so incredibly fast that part throttle was difficult. Please start a thread when you do it and document it.It will be a Holley HP system with a dual sync distributor. So sequential port injection and timing control as well as some limited data logging. It is drag race only application with a short exhaust system so I'll have it open loop up until 2000 rpm and then go closed loop. The car runs down the track between 5000 and 7500 so it should run okay. Might take some work to get it to run clean on the two step and to launch hard but I'm not worried about WOT. We'll see how it goes. I've tuned 8 stacks before but not this Hilborn setup. The Hilborn setup is brand new so who knows what we'll run into.
