Not on a big block. BUT the small block depends on the year. What year is your poly mounts?So will the motor mounts from a 318 poly work on an LA 360 or a Big block??
I have one of those in the kitchen, bedroom, attic, garage and behind a shed in the shady part so it doesn't get sun bleached.OK. So here's how solve that.
There's a device called a thermometer. You can find them in a general store or five and dime.
They look like this.
See the red color? Line that up with the numbers under F. That;s the termperature.
If you live in the country, a lot of people have one like this outside the door or window.,
The needle points to the temperature.
Just like a reading a clock. Remember those?
The poly is a 66 and I have 74 360 or 72 318Not on a big block. BUT the small block depends on the year. What year is yours
For all of you range shooters....
It should. The poly mount will be a little bit wider than the 360 but that can be shimmed to take up the slack. The 318 Should be a direct fit.The poly is a 66 and I have 74 360 or 72 318
It all depends on the range. Nothing I see there is problematic unless it was against the range rules.
Actually what I think is problematic is the parking lot's relationship to the firing line.
Besides that guy is slow.
This is what fast is like.
What was he shooting?I seen him once at knob creek. They had him race a fully auto AK47. To see how many shots he could get off in the time it took a Full auto AK to go thru 30 rounds. He got 25 shots off in that time.
A revolver of some sortWhat was he shooting?
That holds 25 rounds?A revolver of some sort
No he had to reloadThat holds 25 rounds?
Not that fast. No wayNo he had to reload
You might want to google him. He is the world champion speed shooter. He holds more speed shooting records than you got coffee cups! There are all kinds of videos of him racing his revolver with reloads. He is amazingNot that fast. No way
In that video where he bested the world record you can see him shoot 12 rounds on target in under 3 seconds.Not that fast. No way
Not kidding. The dude is fast. And yes that fastNot that fast. No way
On full auto, it can do just over 30 rounds in 10 secondsIn that video where he bested the world record you can see him shoot 12 rounds on target in under 3 seconds.
I don't know what the reload portion of that time is but surely its on the net somewhere. Lets say its a second, that would mean he's capable shooting 24 shots in 8 to 10 seconds.
What's the rate of fire some AKs?
Depending on AK, the full auto fire rate, which isn’t the cyclic rated, is about 280-320 rounds a minute. The theoretic cyclic rate , that is rate without resistance is 600 rounds, but that’s not actually achievableIn that video where he bested the world record you can see him shoot 12 rounds on target in under 3 seconds.
At lot of ranges for insurance and safety purposes have rules against full auto or rapid firing.????????????
440Pick a number. Any number...
