Harbor Freight 4 inch cut off wheel. The arbor size for the wheel is 3/8th.What size do you need. It means what is your shaft size and make?
OK nuff said your in HF jail. Thought it was another brand. Like I have said in the past HF is ok if your life does not depend on it.Harbor Freight 4 inch cut off wheel. The arbor size for the wheel is 3/8th.
Speaking of Ray's. How's OMR doing? It has been a couple years I think. Saw you at Carlisle.Not me anymore. I'm just rolling along, and you.
Neither can Summit racing, I told them do not ship wheel without verifying by measuring, the backspacing..I am sure it is Metric with HF stuff. The Chinese cant read a inch ruler.
About the same here but doing fine.Everyday seems the same up and down, in and out, always moving and you?
Some things never change I could be away for years and pick up right where I left off.
Your all nuts.
Just a little part of me is!Some things never change I could be away for years and pick up right where I left off.
Your all nuts.
Some of us are bolts!!!Your all nuts.
Don't ask don't tell............RH or LLH?
Only if you helpOh Crap
Chris can I watch you grind please?
Wife wont let meOnly if you help
Excuses excuse, too big of a job for youWife wont let me![]()
