Where to buy Mopar Ralley wheels?
Velocity111
New York
Looking to buy a set of Mopar Ralley rims, 5x4" - 14x6 front with a 195/70/14 tire, and a 14x7 rear with a 215/70/14 tire.
Talked with Coker, and they don't have the fronts and don't know when they'll get them. They also have no 195's at all, so they're kinda out.
Is there another seller who has a good selection of wheels and tires? I can also piece together, as I know tire rack has the tire combo I need, but only in all season radials, would rather just have summer tires.
Who else out there sells the classic style mopar rims?
Thanks in advance.....
Looks like you are after small bolt wheel. To the best of my knowledge no one makes them. large bolt is available and affordable through various wheel companies its disappointing and also good if you own the large bolt chassis. With small bolt you have to hunt and scrounge around for used and they used to be like $50 a piece I'm not sure what they go for now.
Hellrats - thanks for the lead, will check them out.
Thanks to all of your quick replies. I know there's a set out there somewhere, just need to find them.
I need to pull a front and rear and measure the back space on them. Standard BS seems to be 4" for the front and 4.25" for the rear, but who knows what i actually have?? more to follow....
If you are looking for used wheels, start a wanted thread. Summit has Wheel Vintiques. I have bought Rallys from them for my Swinger. They are available in different widths and both 14 and 15" diameters in 4" and 4 1/2" bolt pattern. Make sure of what you need before buying.
classic industries 14 x 6 x 7 x8 15 x 6 x7x8
I'm in luv cragar 360's !
MW832 - 14
I think Stockton Wheel may also carry them. They do custom sizes.
Good advise.
I never grow tired of looking at your Dart, BTW!
All - thanks for all the leads. I recognize how difficult it is to find anything in 14" but don't feel like dealing with any fitment issues, so I'm keeping it small. I'm confident that one or some of these leads will get me connected with what I need. I am going to pull a front and rear to confirm back spacing, but will order quickly from there. Thanks again to all - and if anyone else has leads don't hesitate to post them, I'll check them out or someone else may benefit as well.
Up front I have 14" X 5 1/2" factory Rallyes with P195/75R14 Toyo Extensa A/S tires. Out back I have 15" X 7" WheelVintiques Rallyes with 245/60R15 Mastercraft Avenger GT tires.
I have been running cooper cobra 14's and I like them. Cheaper than Radial TA's.
Too bad your not closer, I have a shelf full of SBP ralleys.
I got mine from Wheel Vintiques. They come powder coated very close to the factory color. I got the standard front wheels through Summit - if you get tires at the same time they will mount balance and ship ready to install. I got the 14x7s on the back from wheel vintiques directly because I wanted a non-standard offset so that what you saw from the side would look the same front and back (the extra one inch is all on the inside). they will build the wheels anyway you want them and I think the extra cost was $50 for both wheels.
Summit Racing has those wheels:
Wheel Vintiques 61-4854458 Wheel Vintiques 61 Series Chrysler Rallye Silver Wheels | Summit Racing
Most of the Rallye type of wheels are out of stock everywhere. I recently ordered a set from Coker and they said it will be 10-12 weeks. Ugh! Be sure to check the backspacing you need before ordering.
I’m going to check back spacing on both front and rear, just to be sure, but I wonder if it’s really needed? Every Ralley rim I see no matter the mfg or seller are all the same- 14x6 come only with 4” BS, and the rear 14x7 only comes with 4.25” BS. No matter what I actually have, that’s all I can order- short of ordering completely custom wheels - which I don’t want to do.
So will my BS measurements really matter??
Both those backspace numbers you listed will work just fine. Factory backspace on a 14 x 5.5 is 3 5/8". Backspace on the factory 15 x 7 is 4 1/4". So their fine.
Frank
