- Joined
- Mar 17, 2018
- Messages
- 13,403
- Reaction score
- 30,484
Ok found one, I did not think I had a true front end pix of Demon yet
Good AM men
So Dave gave me a little info on headliner install, I unglued the sail panels this morning, I will see if I can get it better....
It did. But I think I could get it better...You are brave to try that, good luck! I thought it looked pretty good.
Well, call me stupid, BUT I am going to order another and do it again......There is one cut that ripped and it can be seen, and it bugs me.....I bet I do a better job the second time around!!! And the front bow sleeve was not in the right location, I was going to just leave it, BUT.... It was made wrong, it sits about 3 inches to far to the rear and the bow will not stand up.....Seems I am not the only one with this issue....Good AM men
I bet flex seal will fix that cutWell, call me stupid, BUT I am going to order another and do it again......There is one cut that ripped and it can be seen, and it bugs me.....I bet I do a better job the second time around!!! And the front bow sleeve was not in the right location, I was going to just leave it, BUT.... It was made wrong, it sits about 3 inches to far to the rear and the bow will not stand up.....Seems I am not the only one with this issue....
I paid 89.00 for the headliner in 2016. Now it is 260.00 Same thing, same place....WOW!!!!I bet flex seal will fix that cut
Nope.Flex Seal lookin' better now?
Nope.
They used to do pretty good work down there....Tuck and roll...TJ is just down the road a piece When you pick it up, just make sure you can see the dome lamp Dad took the '57 Ranch Wagon down there. Two tone blue tuck and roll. Didn't notice they had covered right over the dome lamp until the first time he opened the door in the dark and the head liner got a strange blue glow
That's why my headliner is still torn. Joel, my upholstery guy, said I wouldn't like writing out the check for installing a new one in mine, especially with the glass in.So some tips. Do not cut the bow pockets to much, or to little. And Heat up some as you go, the back on a 66 is a *****. And where you have to glue down, cut excess materiel from behind, otherwise it leaves a lump....And be careful not to cut to much or rip it.
Had a car done down there, looked great, BUT they used newspaper for padding!!!! Did not last, imagine that...TJ is just down the road a piece When you pick it up, just make sure you can see the dome lamp Dad took the '57 Ranch Wagon down there. Two tone blue tuck and roll. Didn't notice they had covered right over the dome lamp until the first time he opened the door in the dark and the head liner got a strange blue glow
Hm. it would seem that the crunchiness of the paper would give it away pretty quickly.Had a car done down there, looked great, BUT they used newspaper for padding!!!! Did not last, imagine that...
