512Stroker
We are all here because we are not all there.
I am looking for the cam card info for a Mopar Performance Purple Mechanical Camshaft - P4120653AE
Thanks
Thanks
More specifically I am looking for the valve timing events found on the cam card.
Dam the luckThey were never given by mopar
Be pretty tough to do a thorough job to degree in the camThey were never given by mopar
Thanks
MoPar have instructions on how to set it up the simple way. As long as the camshaft was ground properly as per MoPars specs, there should be no problem at all.Be pretty tough to do a thorough job to degree in the cam
So, aftermarket cam manufacturers include the timing events on a cam card so you can make sure that they ground it properly?MoPar have instructions on how to set it up the simple way. As long as the camshaft was ground properly as per MoPars specs, there should be no problem at all.
I do not have this cam yet.With the cam in the motor, and a few minutes with a degree wheel and a pointer....... you could have the events for any lift point you choose.
Is that a misprint for cam with 102 installed centerline?Here you go. Just scroll down to the part number. It's all right there.
Chrysler High Performance Cam Data
102 ? which cam ? I did not see that.Is that a misprint for cam with 102 installed centerline?
If given recommended installed centerline number, can't you simply Calc the events?
4529343. Sl/6 mech.102 ? which cam ? I did not see that.
No you cant calculate it on paper
You can measure the valve timing events with a degree wheel after it is installed.
As an example:102 ? which cam ? I did not see that.
102 is most likely correct the intake lobe centerline is 102*4529343. Sl/6 mech.
Oh, I think you can Calc the events. Maybe not at 0.050", but the theoretical events, which is the way Mopar used to advertise them.
Wrong, see #18102 is most likely correct the intake lobe centerline is 102*
Im sorry I should have clarified you cant calculate all the data points given on a cam card. And I trust a degree wheel to be absolute.Wrong, see #18
My point wasn't to prove you wrong. It was to show you don't have to have the cam events printed FOR you. With just the cam centerline, & advertised duration, you can derive the theoretical cam events.Im sorry I should have clarified you cant calculate all the data points given on a cam card. And I trust a degree wheel to be absolute.
This ^^^^Im sorry I should have clarified you cant calculate all the data points given on a cam card. And I trust a degree wheel to be absolute.
Not exactly true but …..My point wasn't to prove you wrong. It was to show you don't have to have the cam events printed FOR you. With just the cam centerline, & advertised duration, you can derive the theoretical cam events.
I've never tried to derive the events from the @ 0.050" , but it can probably be done as well.
I disagree. I think it doesn't matter where manufacturer, "X", wants to start measuring duration. If they give you a recommended installed lobe centerline spec and a duration spec you can derive the events for whatever their particular method for measuring is, as long as the opening lobe profile and closing lobe profile are mirror images of each other(symmetrical about the lobe centerline).This ^^^^
Most calculations are done with a know advertised lift point of let’s just say @ .006. If you start running through a Comp Cam catalog, only certain cams are advertised in this way while others are at different points.
Now travel onto Crane Cams, Howard’s, etc….
You’ll find the same thing.
