So, who has used the reproduction top plates? Both the one around the shifter and the door.
They are made overseas so the threads in the door section are metric. I could take the door to the hardware store to find out what size/pitch the screws I need are but I thought I'd check here first and see if anyone knows off hand. PG Classics didn't know.
Also, the top plate is held onto the console body with "studs" and thread cutting nuts. The studs aren't tapered like the factory ones so the original thread cutting nuts don't work. What size have you used? Same goes for the thread cutting nuts that hold on the shift indicator assembly.
