You need to quit f’n around and build that vert!That truck went for 17 grand. a good deal, I backed out on it. Wife would kill me..... I had the top bid till seconds before it ended.....Whew!!
nooooooo...... I'm good at checking for cops before I do something stupid.That's what I said at your age.
Have you ever got a ticket yet lol
This oil pan leak has me pissed. Got onto that to long for sure..... Pan going back on, again, today. Won't leak. yea right....You need to quit f’n around and build that vert!
I liked that custom bed that other one had....
I am beginning to worry the leak is behind the block, up higher, like a gallery plug. Not good.....This oil pan leak has me pissed. Got onto that to long for sure..... Pan going back on, again, today. Won't leak. yea right....
Seems getting ANYTHING is a challenge anymore.... Been waiting weeks for a Mopar adapter for Holley carb. From Holley......So I just got a nasty gram from Summit. I ordered a pair of SS springs for the Demon, they have left and right. They sent me one spring and I figured other is on back order. No worries right? They just sent refund and no spring in sight? WTF good is one SS spring?
Also looked like it could have been on a later chassis.....I liked that custom bed that other one had....
Just weld the plug in.I am beginning to worry the leak is behind the block, up higher, like a gallery plug. Not good.....
You could just make one out of wood like people used to.Seems getting ANYTHING is a challenge anymore.... Been waiting weeks for a Mopar adapter for Holley carb. From Holley......
Cannot get to it without pulling engine or trans..... If I have to....I will....Just weld the plug in.
The bolt pattern was a modern pattern.Also looked like it could have been on a later chassis.....
Reasonable men are sometimes pushed to do unreasonable things......Cannot get to it without pulling engine or trans..... If I have to....I will....
We should have gone half'sThe bolt pattern was a modern pattern.
That’s all it takes is whiskey??I got to have a place for OMR or Tim to stay on their cross country jaunts! Craig, Cheryl and TMM get to stay in big house cause they bring whiskey!
Finds the weak spots too!Pnematic descaler makes fast work of it.
Booze for breakfast.Well. Breakfast time. Vista village pub. Friends own it....great food and booze
On these old cars, pulling an engine should be way less than an hour even with power options, it usually takes me longer to set up the engine crane and get it hooked up than it does to disconnect everything.Cannot get to it without pulling engine or trans..... If I have to....I will....
