Stop in for a cup of coffee
The v-8 cars had the larger bolt...
The SS springs will be bolt on and go...
I've never used the longer shocks... When does the rear suspension become unsprung????
However to compensate for the stronger right rear spring, crank up the left front torsion bar some extra so the front end sits level....
I actually appreciate the higher right side stance. Why change the perfect look. Fast cars sat crooked back in the day - from what I remember and read/pics about.
The right rear will still sit a little higher after you crank up the left front torsion bar... Keep the front end level for handling...
I did read you can go with P4529514 shocks - longer for these springs. Or a replacement shock from a 70-71 Chrysler Imperial as they are already longer.
I don’t know what mine had. I cut them out and disposed of them. Now I’m wishing I’d kept them. For another project I need to do
I didn’t throw out anything unless it was a pile of rust. Amazed at some of the stuf I removed that others needed. Even on one front spring hanger that was shot, I knocked studs out to save another one.
B Bodies and the C body shocks are the same. I didn't look up E bodies but the A bodies were different. (stock length)
With just 2 hours to go until sundown, I'm not confident we will attain our predicted high temperature of 80° today :rolleyes:.
We will just have to be satisfied with our lowly 72° and hardly a breath of wind :rolleyes:
87 here right now....
The MP suspension says to use the Imperial rear shocks as they are longer, but I don't think that's the case anymore. I ordered some while I was still at O'Reilly and they were the same extended length as the A body shock. I was kinda disappointed. I think it's another case of the aftermarket compiling several part numbers into a few to stop from having to make so many.
p5d21ItE8rmQMOrZwYcHAKq2ERmUgNi0GSj8xbf-Rt2vOAz7xJAUs33FRf7pXN_S-OPrxyAh&_nc_ht=scontent.fsan1-2.jpg
