ratty dart 340
As it turns out, the problem still isn’t fixed. We car will start every time regardless of the door being open or closed, but there is a new problem. The car dies instantly.A straight up wire job is OK. What You are having, is a damn NIGHTMARE! GLAD YA GOT IT!
the original problem reversed itself somehow. It used to be that there would be one spark on shutdown. Now there are no sparks when the key is released from the starter. If I were to hold the key forward, it would constantly run, but the second you release it from the starter, it dies.
could it be the rotor phasing and or timing? Maybe when the key is pulled back from starter, the spark is getting sent and not making contact in the dist. Cap?
