The problem is turning on the slope. Ours is in continuous until it drops off a small 8 ft cliff into a creek.Steep slope I got steep and works fine. Just go down hill in certain spots.
That complicates things a bit!!!!!The problem is turning on the slope. Ours is in continuous until it drops off a small 8 ft cliff into a creek.
Drag chute?The problem is turning on the slope. Ours is in continuous until it drops off a small 8 ft cliff into a creek.
That sounded like a fun projectNice that six Pack car is fixed, learned alot from that one.
Next time you put a dual point on the machine I bet you will test each set separately.One set had a slight blueing to it, prob from the condeser opening, changed that got a bit better but nothing showed up just at around 2800 RPM or so. Weird one for sure add old fuel, blown powervalve, changed and got better, two guys not versed on a six pack set up Yada, Yada, Yada.
Dwell was rock steady at 42 also. Just weird.
Speaking of dual points, I need to pull mine out this spring for a fresh set.I always do when I build them. 30 each dwell +_2 and 40+_2 both. This was troubleshooting a problem at a specific RPM..
I need to pull mine out this spring.
Same here, was told the same thingYes. Went to a local outdoor equipment shop last summer... all they had in stock were zero turns. When I described the yard topography, the guy said i should stay away from a ZT mower.
Spring has sprung, nice and green hereSpeaking of dual points, I need to pull mine out this spring for a fresh set.
well, its been good, just busy. started a new job at a mechanics shop after school so that has taken up all of my time. I changed the oil in the beast yesterday and I beat my buddy's 370z friday. Prom was Saturday; couldn't take the beast but I found out that a lot of the alumni have heard of it and it has quite the reputationHaven't seen you wandering the virtual hallways.... How's school and the Beast?
