Safe max RPM for bone stock 5.9 magnum
skep419
5.9 Magnum 4 speed afficionado
Minesoooota
I've read 5,000-5500. 2001 engine, speedmaster intake, 750 holley, dougs d453's
I'm using an old MSD 6al box and currently have a 6000rpm chip. Wondering what chip I need to purchase just to be safe? Thanks
I shift mine (200,000 miles) at 55-5600 rpm's just because that's where it likes it, but I've had it to 6k multiple times no issues. I wouldn't fret a bit at 6k. That's with a small regrind cam and hughes spring kit. However, the bottom end is untouched
The valve springs and cylinder head ports will stop you when you get there. Just because you can doesn't mean you should.
Never been rebuilt? I think that is pushing it
I never even pulled the pan.... she's running 13 flat in a long bed D150. I've done nothing but pound out of town and at the track since installing. By accident I hit 7k when the tires broke loose. Mild regrind cam and Hughes spring kit.
A flat 13 seconds with a stock long block other than the cam,no cylinder head work? That's impressive.
I used a dremel at home and cleaned up some casting on the heads. It will go 12's, I was against a stiff head wind and trucks don't like that ! LOL
It is a brick but a well tuned brick. Impressive.
Hopefully it's sending a message.... Not everyone has to spend money their budget don't allow to have a little fun. Just think if the drive train was in a 3000 lbs A-body. And these magnums with any care are perfect street engines as they are when used on the milder side of things.
But I don't have a small regrind cam or a hughes spring kit :poke:
well, when you said "safe rpm for stock" I was taking it you were concerned with the bottom end coming apart. If you just want to know where it will shift, you'll have to go by trial and error. I know the my '01 Ram has will turn 5k with kegger intake. It's still factory single exhaust and all.
Stock cam and valve Springs are done at 5000
My stock long block 5.9 is done by 4500, can’t miss it.
I find it hard to believe that a stock 360 will run 12's, even with a mild cam and only casting clean up.
Start re thinking on how things can be done. The 5.9 has a 9.0-1 ratio stock. While a slight light on squeeze, it’s not bad and will work with mild cams. After that, it’s how well you 1; tune the engine & distributor, 2: get the power to the ground, 3: maximize the gearing to make max power at the finish line stripe. You’ll want to trip the lights where max power is being made or very slightly there after.
Just remember your camshaft has to fill the heads as much as possible, close the valves at the optimal time and then the ignition ignite it off.
12.4's with a stock 360 with nothing else then a mild cam, only casting clean up, no port work, comp valve job.
It's not hard to do the math. The weight and the wind will spell it out for you. I know my truck has a 12.9, it went 13 flat first time out against a stiff head wind. I know people there and their CARS were off ET/MPH, so I know my truck was. Now, if you give it a tenth per hundred pounds, plus the wind resistance, 12.4's should be pretty average in a 3k pound A-body.
I’m worried about breaking parts.
Sounds like a great start! If you are sticking to the kegger intake, they are not made for RPM's. 4800 is about where you are going to shift.
