Depending on which ones. The ones with a hole in them to access the backing plate bolts cause a problem.You can also have your shafts drilled to the bigger pattern
I have these on rear of 66A lot of tires but not a big choice. BFG has 235-60's. Tires - Truck Tires, All Terrain Tires, Car Tires, Mud Tires & More | Summit Racing
Is your car mini tubbed or the wheel openings trimmed? 15x7's is about as wide as you can go without modifications. Probably 15x10 with a mini tub and the right size tire.
Agreed. They may be tough to come by. Those are old wheels back when they didn't make small bolt in 15". I'll keep my eye open. I am a fan of the A12 look with the black steelies and chrome lug nuts. It's a racy look where all 4 matching wheels is a little more refined.
No, not mini tubbed or trimmed. I have 15x8 with 4" BS with 275 60R15. I went with 15x8 instead of 15x7 so there was less sidewall bulge for clearance. Fit very nice with stock suspension, but I now have SS springs so it is quite tall.
I've seen that shown but never tried it.Have you ever tried a Merit disc or what I used for handgun sihloutte shooting was a piece of tape with a 3/32 hole. Makes rear sight, front sight, and target on the same plane like a camera lens, Works fantastic.
One thing I’m learning is that no matter what, there is gonna be a controversy on any given topic these days. For example, did you know that Mustang II rotors will fit and function on A body spindles... National bearing company makes a bearing that will work for it and let it happen. But no one has really tried it in the real world. But on paper, it looks like it’s work.@Mattax Matt mentioned this too. There is some controversy over this. Seems some think it is ok if using screw in studs but I just don't know if it is all worth it.
I have heard this. They used kH brakes as Well... Not on mustang 2. From what I heard direct fit...but never tried it. There is a member here @HemiGTX I think. Rebuilds KH brakes. He would know for sureOne thing I’m learning is that no matter what, there is gonna be a controversy on any given topic these days. For example, did you know that Mustang II rotors will fit and function on A body spindles... National bearing company makes a bearing that will work for it and let it happen. But no one has really tried it in the real world. But on paper, it looks like it’s work.
Nice here this morning, but rain is moving in. Wife mowed the yard this morningI was all caught up at 03:30. That'll teach me for goin' back to bed for more needed sleep.
30 minutes ago I was making coffee and the sun was blinding, not anymore, June Gloom moved in.
Welcome to the club. It goes like that...Once upon a time, in a land far far away, Chris set out to do a "simple" front disc brake upgrade. A K-Member swap, underbody derust and paint, undercoating removal, steering gear replacement, brake line replacement and exhaust system reconstruction later..... Chris starts on the disc brakes.
Who’s the lucky suck gotta mud all that?Here is pix of the bar area, the green wall is the bathroom. I will have a nice long bar and a pool table. I am trying to get over to see MeMike this trip but not sure it is gonna work out. Lots to do here yet. I added a pix of our kitchen at present!
16 weeks since going up on jack stands.
Nice here this morning, but rain is moving in. Wife mowed the yard this morningwhile I taped/and did first mud on the drywall.
