hotrod swinger
1966 Plymouth Valiant 225
Rebuilt engine
Confirmed TDC by watching valves
Plugs in correct firing order
Distributor set 10 BTDC
Petronix kit instead of points
I can start and run the engine with the choke on and high idle.
Once I reduce idle and/or open the choke the engine dies, usually with a spit out of the carb, sometimes flames.
The engine will not idle below 1500 rpm.
This is my first time starting a rebuilt engine by myself so I’m possibly missing something obvious.
Rebuilt engine
