What does the single wire off the 1 wire alternator do? It charges the battery and runs the car. I have no idea why you would think that is a field wire... a 1 wire doesn't have a field wire.
The main alt charge cable runs to where you have that yellow wire. You use ALL the OEM stuff up front, EXCEPT the OEM black charge wire that hooks to alternator. That black wire powers the car and you need it disconnected to isolate the alternator and battery from the other side of the cut off switch.
Follow the schematic EXACTLY, it works.
You see my picture. The black wire from cd going to right is power to the cut off. The other black wire going forward hits the starter relay. That is the ONLY wires attached at the cutoff switch. I also have a 60 amp maxi fuse in line to the cutoff. No alternator or starter cables.
I don't think that wire is a field wire. I was just saying that I have a stock alt. (I think I got confused about the field wire because 67Dart273 and Mattax's diagram used it.)
Anyway, after I disconnect the yellow wire from the field wire, as I have it now, I connect it to the charge post of the alt., and leave the original disconnected.
I believe other than that, that's all I have wrong.
One complainer was 300+ back years ago... ironically funny to me.
