Stock 340 dyno tests?
First article, Dyno Derby, is garbage. Stock headed/rocker armed XE268H making almost 400hp, yeah sure it is.
That dyno is known to be a little on the happy side imo.
Not exactly stock heads with a multi angle valve job and bowl cleanup.
Dont think there is enough cam to get it there at any rate.
The dyno derby one the heads weren't messed with IIRC. no porting or clean up.
"treated to a performance valve job by JMS Machine"
Open to interpretation I guess, but it isn't a stock type valve job. At least 3 angle possibly more. Either way doesn't make sense to do a 3 angle and leave the ledge without blending it into the bowl.
[/URL]
Performance valve job means they at least did a little bit of blending into the bowl maybe even smooth out a little bit of casting here and there. Gasket match intake to head, nah they didn't do that.....
My completely stock 50,000 mile 1968 Formula S notch ran a best of 14.2 at I think 98 MPH. I am sure about the ET, not as sure on the MPH. It was a long time ago. The car had 3.23 gears and 185/70-14 radial tires and didn't spin at all.
Here are the specs of the 1968 340 GTS that ran in the TV series "Manix.
'68 340 10.5:1 cr
275 hp @5000 rpm
727 auto/ 3.23 rear gears
1/4 mile mid 14s around 95 mph.
According to various magazine tests of the day (1968).
Manix 1968 Dodge Dart GTS
(3 minute video)
This is probably the next best account after the magazines from the 60’s. If it was 98 mph and around 3,200 lbs that should be about right for ~275 crank hp.
My stock cam, stock head, standard bore original '69 340 X head ran many 14.0 1/4 mile times and one time dipped into the 13s (once - think it was a tail wind). Street radials, crappy headers with dents, 2 1/4 full exhaust with some crappy mufflers, stock choke exhaust tips, 727 stock like converter, 600 Holley and 323 gears full interior. I think I used to take the spare tire and jack out of the trunk air the front tires up a little bit. Hardly the ideal drag car but it was a strong runner compared to most other "stock" engines back in the day. It could fend for itself out on the street fairly well and no problem doing smoky burn outs.
.15-.20 of that is racing in Maryland. Then subtract for headers, carb change, and radial
Tires is a biggie with what is available now compared to over 40 years ago.
August 1969 Hot Rod Magazine dyno tested a 340. Stock, made 280 hp at 5500 rpm. That's engine dyno, not chassis. One of the very few motors, maybe only motor, that made more hp than the factory rating.
In the mid-1970s, my 65 Barracuda with a low compression 72 340, stock except for a Torker intake and 3310 Holley, 4-speed, 3.23 gears, street tires, ran consistent 14.10s at 99.
Switching from stock 340 exhaust manifolds to fenderwell headers got me down to 13.70s at 102.
A while back a member here stated that a Chrysler engineer he knew quoted 320 hp
I read somewhere about 10 years ago (probably Mopar Muscle Magazine) that the 340 came out in 68 which was the same year as the Road Runner. Ma Mopar was not about to admit that the new small block (at 320) had almost the same HP as the 383 in the new Road Runner (335). All I remember is that I DID read it in a magazine I trusted.
Tire size, gears, weight, those variances matter, No?
yes i used my specs e70 bias ply and 3.23s hi-way gears 14.3@97 mph not 3.91s or 4.10s
a strong 68 to 70 340 puts out 310 315 hp with the chit stock carb 330 335 hp with a non chit carb
If you turned slower then 14.5 you coudnt drive or got a weaker motor
340 A bodys turned mid 13s to 14.0 mph stock there is dozens of road test showing this as well what more needs to be said after 91 posts
time resign from this thread
Wallace Racing has a calculator for HP and ET based on inputs you provide. ET-MPH-HP Calculator
My 340 Formula S FB ran a best of 13.48 @ 105.38 pure stock with a A727, 3:55 gears, and H70x14 tires. This was essnetially at sea level in SoCal (OCIR, Lyons, Irwindale, Pomona, etc). The car weighed about 3200 and I weighed about 185 so total weight was 3385. Using the MPH/Weight estimator, I get 305.23 HP. This is the best estimate as using the ET/Weight estimator is a function of traction and ability more than engine power. Using 13.48@105.38 in the calculator yields 273.13 HP. If you put the 305 HP into the top equation which estimates ET and MPH, you get 12.99 @ 104.04 MPH. This is what a car should do with optimum traction and driving skill so it shows how much improvment is possible with the power you have.
Fun and useful information to play with.
Too much is made of hp.
The 340 a body was just well balanced and quick.Pulled hard from the lights to well past highway speeds with decent mileage!
Would like to add. The "DART" is well balanced with the 340, not just the "A" body, as in a Cuda. The extra trunk in the rear help with the Hook-ups. Not so sure about the "decent mileage" either, I drove my 69' Dart around the neighborhood yesterday and the fuel gauge looked like the minute hand on my watch. Sure was FUN!!!!! Sorry to say, Yes I am one of those, "once a month driver now", but still need my fix.
LOL…too funny. And absolutely true.
My first car was a 72 Demon 340 4 speed. Is only been driving a few weeks and all my friends and I (we had the experience of exactly ZERO with anything except trying to get the girls in the car) had convinced ourselves that this thing was turning 7500!!!
I told my dad what I thought and he said you are all full of ****. You’ll be lucky if it’s turning 5500 and that’s a stretch.
The next day I skipped a class and ran to the local speed shop (you could do that in 1980) and snagged a tach. Wired it up in shop.
And the disappointment was staggering. 5100 and that was it.
That was all she had.
I seriously considered taking the tach out because it hurt my pride a bit but I sucked it up and left it in there.
The tack, chrome valve covers and chrome air cleaner makes the car faster. Those were our first Hi-Po add-ons.
Nick's Garage has a nice video of dyno testing a 1970 340 for a 'Cuda.
Engine made 335 HP initially. With tuning it pulled 340.2 HP and 345.7 f-p of torque.
Nick tested a modified 340 with E-brock heads, AirGap, Holley DP, Cam was 0.525" lift, Engine made 395 HP after 10 pulls and tuning.
My 340 for my '68 FB FS will be similar but with a Purple Shaft 280°/0.480" cam for more streatability. I would be happy with 340 HP.
Yep , MPH is horsepower. E.T. is just E.T.
Most 340's were pushing 250-260 HP at the crank from MPH being posted.
Yours is a well tuned and sorted combo. :thumbsup:
I raced my 1969 Dart GTS at Martin in 1972.
i bought it used for 1200 bucks.
it came equipped from the factory with 3.55 gears.
only upgrade was cheapie headers and glass packs.
it went 14.23@ 99 mph late that summer. Was my first ever track outing
