PRH
I think you should post a pic of what you think is the correct setting.
No that is not the problem. The correct answer is you need to get your tail in gear and degree the thing, and NOT depend on either the balancer mark or the timing marksFound the problem. Timing chain was installed straight up matching both 0s as per directions. Installed properly i had to match the 0 on the top gear to the rectangle on the crank gear. Must be a factory defect.
I've installed many a cam and timing chain and never degreed them. Lined up the dots and no problem. I'm not saying that it shouldn't be done it's I never had any problems with the valve's hitting the pistons and we installed performance cams the same wayNo that is not the problem. The correct answer is you need to get your tail in gear and degree the thing, and NOT depend on either the balancer mark or the timing marks
How do you even turn the engine by hand after installing the valve gear?
I agree, years ago we'd slap a cam in dot to dot.I've installed many a cam and timing chain and never degreed them. Lined up the dots and no problem. I'm not saying that it shouldn't be done it's I never had any problems with the valve's hitting the pistons and we installed performance cams the same way
I agree. comparing parts is one of my pet peeves, I like to know if a new part is within spec of an old.Quality was better then. And it’s INSANE to not spend 20 minutes degreeing a cam.
I don't give a **** if you've installed 2746.5 cams and timing gears. There has been cases of them being mis-marked, and there's even been cases of cams being ground wrong. WE HAD ONE MEMBER ON HERE who could not get a new engine started and YUP!!! It turned out that somehow he had gotten ahold of a reverse ground marine camI've installed many a cam and timing chain and never degreed them. Lined up the dots and no problem. I'm not saying that it shouldn't be done it's I never had any problems with the valve's hitting the pistons and we installed performance cams the same way
I can tell you how to check if the gears are miss marked and it's easy to do, compare the new gears to the old ones.I don't give a **** if you've installed 2746.5 cams and timing gears. There has been cases of them being mis-marked, and there's even been cases of cams being ground wrong. WE HAD ONE MEMBER ON HERE who could not get a new engine started and YUP!!! It turned out that somehow he had gotten ahold of a reverse ground marine cam
You don't know if the old ones are right!!!!I can tell you how to check if the gears are miss marked and it's easy to do, compare the new gears to the old ones.
I understand what you're saying.You don't know if the old ones are right!!!!
I had a piece of electronics test equipment by a well known manufacturer. Hewlett Packard. Maybe you've heard of them. In the old days they made THE world class high end STANDARD of test equipment.
Could not get it right, kept failing in part on one circuit, and of course that is why I got it cheap. Turns out I was not privy to an update bulletin. There were a couple of components in a circuit that were incorrect, and were updated from the factory, except mine was not, and the DIAGRAM in the factory service manual was incorrect as well
You sound like you don't believe that someone was able to install a cam and timing chain and not have problems.I don't give a **** if you've installed 2746.5 cams and timing gears. There has been cases of them being mis-marked, and there's even been cases of cams being ground wrong. WE HAD ONE MEMBER ON HERE who could not get a new engine started and YUP!!! It turned out that somehow he had gotten ahold of a reverse ground marine cam
It MIGHT run, more likely not.
Actually rob I think this is it and it's gone up a bit. I believe this is the one I have, which used to be about a hundredYou can get a degree kit for under 100 bucks. A grammar school kid could do the procedure. There's simply no reason not to do it and every reason to do it right. In this day and time, it's flat ignorance to leave that step out, even on a stock build.
