“Max effort daily driver” 318 build vs “Budget” 400 swap
Th general difference STOCK between the old 383 and the little newer 400 was compression. I have had many stock Roadrunner 383s 68-71 and some early 400s. Either would make a fun driver. The 400 is a great base for more hp update later. Sorry, I guess I am just a big block guy. All previous arguements here for the 400 make sense.
A passenger weighs more than the weight difference of the engines.
With alum heads, the difference shrinks.
Front suspension really doesn't require any changes to support a bit more weight. A re-alignment and adjustment of the torsion bars usually works fine. I know my car doesn't dip much when I stand on the bumper, and I weigh far more than the difference between a SB and a BB.
If it were me, comparing putting alum heads on a SB vs putting headers on a BB, I'd be going with the BB and still looking at alum heads. Sell a few SB intakes to fund a BB intake and it's a wash other than the headers, oil pan, and distributor. It's also helpful that the SB is already in the car, keeping it driveable while the new BB setup is being assembled, which means time can be taken to find deals on used parts rather than paying full retail to assemble.
This is how I look at it, at least.
The farther out on the nose, the more it effects the car.
Sitting on the bumper doesn't make mine drag gravel, it might be 'felt' in a side-by-side comparison, but for daily street driving no one will notice it.
For the 318 build I was considering around 9.5 compression, edelbrock heads, flat top pistons and going for quench, not going ham on camshaft selection, etc. Also, I have in my possession several intakes to choose from for a small block build. I even have an old edelbrock dual quad one if I wanted to turn the cool factor up as well. My car already has headers which I would re-use. Logistically this build would be very simple.
What means
"not going "ham" on camshaft selection"?
This does not seem to fit together well with
"max effort daily driver 318"
The 75 Dart is a fairly lightweight car, and for a DD, all you need is a hi-cylinder pressure 318. This will provide all the performance you will ever need in a 3.21 geared automatic daily-driver car.
But I sense from the way the thread went, that you are not fully committed to Daily-Driver status, but are leaning more towards building a modest performance car with daily-driver as an option. Am I right? Cuz why else would you even consider a fat-bore short-stroke 400 cuber?
If I'm right, here are My thoughts;
In this thinking, the overall combo is the big deal; and you will want to always keep fuel-economy in all your thoughts. So then;
The very first thing that you will want to do is select a stall-speed, and the Second thing is the camshaft. After that you would select the grade of fuel that you are willing to pay for, and finally back-calculate the Compression ratio, to achieve the pressure that you can safely run without detonation on that grade of gas.
That' all there is to it.
What I mean is this;
if you intend to run 3.21s and a stock-stall automatic without a Lock-up, this will require a different engine than if running 3.91s and a 3500 stall.
By choosing the 3.21s, you have already limited the rest of the combo. Why? Because the engine is gonna be handicapped by lack of torque-multiplication , and the Mopar"s rather large 1-2 shift split, of 59%.
Lets say that you are gonna run 27" tires.
With 3.21s, and in first gear, your speed is gonna run about 9.2mph per 1000 rpm, so 4000 would be 37mph, 5000 would be 46mph, and 6000 is 55mph. The point is this; that is a lotta lotta mph to be stuck in one gear. So then, the engine build will need to reflect that, as this is gonna be very nearly the only gear of choice at WOT. At the shift into Second Gear, the Rs will drop to 59%, which from 5000 is to 2950, so again, the engine build will have to reflect that. That is a Powerband requirement of 2150 rpm, well beyond the usual 1500 rpm band of optimum average power.
To get the transmission required powerband, to better fit the engine, would require a hi-stall convertor. How high? Well that would depend on the rpm of peak power, which depends on the cam....... but it quickly gets North of 3000, which is usually not the best for fuel-economy.
Furthermore, your take-off performance depends entirely on how much torque gets to the tires at zero mph. This depends a lot on the various gear ratios and the basic engine torque.
Your ratios are already selected as 2.45 x 3.21=7.86.. And at zero mph the Torque convertor will multiply that by about 1.8.... but this number quickly diminishes towards something like 1.1 as the car starts to move.
So whatever torque is coming out of the crank, gets multiplied by these numbers.
Say you have a stock stall of 2000ish rpm, and say your engine makes 200 ftlbs at 2000. Therefore 200 x 7.86x 1.8=2830ftlbs briefly, diminishing to 200 x 7.86 x 1.1=1730 ftlbs as the rpm starts to build. These are lackluster numbers. And you are not a happy guy. So you swap out that convertor for a 3000, and at this rpm say your engine is now making 327 ftlbs. Your new numbers are 4626 diminishing to 2827ftlbs which is a chitload better than 2830/1730. In fact, as you can see, the max at zero mph and 2000 of 2830 ftlbs, is now about equal to the minimum achieved by the 3000 stall TC@2827.
2827 is not that great, but not so bad either, and for a DD I would gladly be happy with that. Now, I'm not saying that you need a 3000 stall Convertor. I'm just presenting a thought-process.
Lets move on; With 27" tires and 3.21s, 65=2600 at Zero slip, could be 100/150 either way on the tach. So for optimum fuel usage, the thought is to have a stall no higher than this. But if your leaning more towards performance, I can tell you that I really really liked my 2800 Turbo-Action, which I purchased back in the late 70s and at that time, it had the name of Dirt-Jerker. Great TC. I still have that TC today, still installed, having been thru many combos.
If yur still reading;
Now we have the basic combo worked out which is ;
318/904/3.21s/2800 stall.
Next up is the gas, what octane are you willing to pay for. This will determine NOT the compression ratio to run, but the maximum cylinder pressure.
Here are the typical pressures to octane numbers, for an iron open-chamber :
87 at 150psi
89 at 155psi
91 at 160psi.
A Quench-design will usually tolerate about 5 more psi.
For max-torque, you would build to the highest pressure
For max-Power at high rpm, whatever octane is sufficient to suppress detonation.
For max fuel economy, you would build to the cheapest gas
Lets say you choose 89, and 155psi, as a happy medium.
Now we're getting into the nitty gritty.
Now is the time to pick the cam.
Getting back to the 3.21s being a handicap, and the 2800 stall, we are looking at a power peak of ;
2800 plus about 1500=4300 This is just about exactly equal to the stock 318 cam.
But this is a DD, so it doesn't have to be a super gas-sipper.
Lets stretch the power band out to fill up all of First gear and if it falls on it's face on the 1-2 shift, we won't lose any sleep over it....... cuz it's a DD; ok?
So then you gotta chose an rpm limit, at which the engine will survive say 100,000 miles, cuz longivity also plays into fuel-economy. Ok then, we know that Mopar small-blocks tend to throw rod bearings with stock oiling systems, after 6000, so lets sneak in at a 5500 rpm shift.
Allowing just 300 rpm past peak for the factory heads, this gives us a power peak of around 5200. Oh well that's just swell, this allows a cam of up to 230@.050 which for a 318 is really big and NOT suitable for getting fuel mileage.
Ima gonna arbitrarily cut that back to a 218@.050 cuz I know I can push that to close to mid 20 mpgs, with iron heads, from point-to-point.
Ok , see how this is working out?
Ok now, using David Vizards "128rule", for performance, this cam should be on a 108LSA. But we're NOT targeting performance exactly, so a 110 will be fine. And we don't want to get into a messy intake exhaust system with a lot of overlap, so at 218@.050 and a 110, we should be good at 65=2650
So this dials our cam in at 218/110 so far.
From experience, I know building pressure with a 318 is a pile of work, so I'm gonna want to run this cam advanced And I know the factory heads need all the help they can get, so I'm gonna recommend a split pattern with about 8 extra degrees on the exhaust, giving us 218/226/110, Awright now we're getting somewhere.
Now, you can get this cam with acceleration ramps from say 58 degrees down to maybe 44 degrees lets go with a typical 48* and that, makes advertised numbers of; 262/270/110
Next lets build the cylinder pressure up to a minimum of 155psi with that cam . In at 109, the Ica is 60* and at 800ft elevation, the Wallace kicks out 154.5psi@9.5 Scr; BadBoom!
Here are all the events;
262/120/114/270/46 in the order of
intake/compression/ extraction/exhaust/overlap
what do they mean?
Well you can't mess with the 120 compression, cuz that is making your 155psi. Tthe 114* extraction is a generous amount with which to make fuel economy. The 46* is a modest amount of overlap, which won't muddy up the exhaust, yet will put a modest yank on the plenum.
Finally, this is an install at 109, just 1* advanced. To fine tune it in your combo, you can advance it 4* to increase the pressure, if you change your mind and are willing to run 91 gas at WOT, should you need it. Or you can retard it say 4* which will decrease the pressure and move the power up a few rpm. Point being, this size of cam is tuneable to your combo. When it gains pressure, the engine will gain a lil take-off performance. When it loses pressure, it will trade low-rpm torque for a lil high-rpm power.
Now
Before somebody says that AJ said that you gotta run a 228/110 cam, read the post again. I arbitrarily reduced the permissable 230* cam, to a 218* cam. And altho I recommend this size of cam, it only applies to all the assumptions I made in setting up the combo.
If you swap out the 3.21s for 3.91s moving your combo OUT of the realm of DD, then the 218/110 cam is wrong!
If you stick with the factory 2000 stall, I think this cam will still be right, but if you get into lo-rpm detonation, yur gonna have to deal with that.
If you want more performance, this engine build is wrong. Well the whole combo is,lol.
If you get a trans with a Lock-up convertor, then you don't have to be limited by a 2800 stall.
If you are not limited to the 2800 stall, then the 3.21s can move down a size, without compromising the as-built combo.
And finally;
I don't see much value, in terms of fuel economy, in running a smaller cam. The 262 is a nice all-round performer.
The next bigger cam of same FTH design, will definitely suffer a decrease in fuel economy.
If you are willing to upgrade to a Solid lifter cam, there are gains to be had either way.
If you are willing to install alloy heads, and a Quench chamber, you can safely run the pressure up to 200psi on best gas, decreasing about 5psi per grade. And you can upcam one size without sacrificing fuel economy, so long as you maintain the pressure. In fact, if you do both alloy heads and a Solid cam, you can upcam two sizes, and move the LCA back to 108 where it should be. I only chose the 110, to not have the overlap that a 108 would bring, a concession to fuel-economy.
Ok, those were my thoughts.
Hello everyone. I am in the middle of this dilemma right now and I wanted to hear your thoughts and ideas on it.
I have a 75 Dart Sport with a 318 in it. My initial plan was just to rebuild it. But in January I acquired a 400/727 combo and now I’m kinda torn on what I should do.
On the other hand, for the 400 I would be needing to buy quite a few stuff before I even get to start spending on the engine itself. I would need headers, a new distributor, and the appropriate oil pan just to get it in my car. It came with a 2bbl, so I would need to get a 4bbl manifold for it. This eats into my budget so if I were to follow this route, I would keep the factory heads and do some porting on them. Valve guides are good so no need to do a full recondition on them. However, I would have 2.14 valves installed since the 2.08s are sunken from a previous rebuild. And on pistons, I’d be using the crappy cast ones. This means a compression ratio around 8:1 after milling the heads. And yes, I would need to buy new pistons since the block has to be bored.
I did some math and I would spend approximately the same on either of these two builds. My car is a regular driver, and I’m putting in a trac loc 8.25 rear end with 3.21 gears.
What are your thoughts? “Max effort daily driver” 318 or should I let my inner teenager take over and swap in a low compression big block?
Easy choice 400, one of the most overlooked advantages for larger displacement is the need less rear gear for similar performance, since most don't want to run too much gear.
Even against a stroked 360?
A 400 vs 408, tq is tied to displacement, even though the 408 has a longer crank for more multiplication effect the 400 has a bigger bore to apply more force to the crank to be multiplied generally evening it out. The 400 has the advantage of being able to breath better though.
AJ, there is a lot wrong and arguable in your post.
This is a description open to interpretation and that open area is huge!
This a weight I’d like to see for clarification.
This is possible but IMO, a looser next to the 400
I agree
Because making more power with a bigger engine is easier. Due to a shear CID advantage, more and better power can be made easier with less camshaft and still use a low gear set.
My ‘79 Magnum had a 318, Edelbrock 600/4 barrel, performer intake, dual exhaust and a mild cam. I swapped this out for a ‘78-400 and only added a Holley Street Dominator, electric choke TQ (AKA Small primary unit) and Hedman headers into a true dual exhaust with DynoMax turbo mufflers. No cam change.
The 400 slaughtered the 318 everywhere AND equaled it in mileage.
Wise words
So then;
Horrible advice and a stupendously dumb idea.
Shame on you!
Camshaft first once the short block is done. You can start with an idea of a camshaft first as a general idea of where and how the cam will work in terms of performance. That’s where that ends.
This is the first step in the whole package. Not the converter or camshaft. With the idea of running only 87 or stepping up to 91/93 it will allow other ideas to roll in and out.
To simple and bad
Arguable, very.
Very arguable!
Let’s say that you are gonna run 27" tires.
Here comes the calculator and assuming long winded writings.
Stuck? Define stuck! The driver of such a combo would only leave the car in this gear that long by choice or not care about it. This also assumes camshaft size.
From a dead stop, yes, not traveling down the Hwy.
More assumptions ?
A 3K drop? Can anybody else confirm this?
More assumptions being made!
Such a shame you make such blanket statements chock full of assumptions!
WTF? LMAO!!!!
Assumptions
More assumptions
87 at 150psi
89 at 155psi
91 at 160psi.
WTH!!!!!!
And… a cam of 230@050?
Oh boy….
Now where talking
And a wider LSA is loosing torque, follow the rules and it’s a 107 w/a 1.78 valve if the compression ratio is 10/10.5-1. Since most cams do not get cut like this, (Thumper) drop it down rather than move up.
But is the future engine a 10-1 or 10.5-1? And running on 87?
That 110 is a basic go to. How does that make a messy intake and exhaust system?
Not really as there is a variance in an acceptable cam duration ether way.
What a load!
Must have low experience
Assumptions being made! You could a lot worse.
what do they mean?
Probably more than he is interspersed in but it’s all good.
(Enter the laughing emoji you hate so much! LOL! :poke: )
So all this calculation is done with what piston, head gasket and cylinder head cc?
Get the right cam in the first place and you won’t be bothered in playing around with advancing the cam.
Now
Is it really?????
I’ve used several cams very very close to your specked 318-218/226 cam and that is NOT an ISSUE at all.
Nothing like writing out a ton of dribble and stating it’s wrong.
LU converters equal big bucks
And finally;
My eyes are bleeding…..
I would at least put decent pistons in the 400, to have a good short block to hop up later, run it 2bbl or whatever compromises you have to build a solid short block.
Bingo!
On the mainland USA, AFAIK, the 400 only came with a 4bbl carb being a TQ in which i highly recommended the larger primary TQ.
For a street 400 engine, no more than 9.0-1 if it needs the rebuild (and it probably does) a TQ carb if possible on top of a performer intake if the factory intake is not available exhausting through standard headers into a 2-1/2 H piper exhaust.
Take the 400 and deck the block a .100". Buy new pushrods and ARP head bolt washers to take up the distance you milled off the block. Re-ring it and put a mild 220's duration cam in, an Edelbrock Performer intake, iron manifolds and you'll have a great running engine that will be cost effective and give you more power and torque than a small block that cost twice the money.
If you use the KISS method you'll have a lot of fun for very little money.
Tom
I still like the 318 here. You'll have it running faster, you'll be way less likely to lose interest plus, you can have longer to build up the 400 for later.
Bingo!
I have a complete 400 engine sitting in my shed, it has a 2bbl on it factory.
one thing i haven't seen mentioned is what resources you have available to you. is obtaining parts (shipping) a concern? do you have a good machinist for the rebuild work?
is the 400/727 complete? if not are parts easily available to you? it would really eat into your budget and morale to have to track down all kinds of parts and then get relentlessly rung up on shipping.
at a minimum you're going to be in for mounts, an oil pan, cutting the driveshaft, exhaust, maybe some wiring work. you may also need to address the cooling system and possibly power steering (i didn't see if you mentioned it was equipped).
you also said that you plan to drive the car like a grandma 99% of the time. so it would seem like the ultimate goal isn't all out power?
personally, i'd go the path of least resistance. you already have the small block, there are recipes to make an honest 400hp with a 318. you already have some of the peripherals-- headers, intake, etc.
my recommendation would be to build that 318 out
You can run 87 octane and have a very fun ride without breaking the bank. You may find that Sidewinders or Stealth heads more cost effective than repairing the iron heads.
If you go with the 400 you will need a transmission as well and who knows, possibly a driveshaft.
What did it come out of?
Thats what mine is also..400 2bbl out of a 72 charger...:eek:
Well I had a 73 Duster with a mild 400 in it .
Had a mild cam edelbrock performer intake can't remember what carb ?
Dual exhaust 727 3.91 8 3/4 sure grip.
I was 19 years old and that was was a blast and a handful!
Talk about tire smoldering burnouts.
There is a picture on .y profile of the car smoking the tires.
I have had many small block a bodies most of them 340 cars.
Some were faster because they were built more.
None had the torque nor did any do burnouts quite like the big block.
400 all the way !
I agree
Wise words
Shame on you!
To simple and bad
Arguable, very.
Very arguable!
More assumptions ?
WTF? LMAO!!!!
Assumptions
More assumptions
WTH!!!!!!
Oh boy….
Now where talking
What a load!
Is it really?????
My eyes bled out, I'm in tears from your AJ like post. :D
What means
87 at 150psi
89 at 155psi
91 at 160psi.
what do they mean?
Now
And finally;
Funny that you mention a 218 @ 0.050 cam for the 318, since the camshaft I'd use If I were to build the small block would be a comp cams 268H.......
I actually started out by picking the 3.21 gears. My car has 26 inch tall tires. Cruise RPMS at 65mph calc out to 2700, and 2300 at 55mph. Going to 3.55 gears would have put my my 65mph rpms at 3000. I know some guys have no problems cruising at 3k rpms, but I would rather cruise below that. Like you said, settling for 3.21 gears puts a limit in my camshaft selection. Although I would still choose the same cam even if I had an overdrive trans and 4.10 gears.
Next thing I did was calc out the compression ratio. Using KB flat tops 0.012" down the hole, 0.028" thick gaskets and eddy heads with 63cc chambers calcs out to 9.5. Milling the heads to 60cc brings it up to 9.9. With a compression ratio in this range, I picked out he comp 268H for 2 reasons. First, in this thread they dynoed a 9.1:1 318 with eddy heads and 252h camshaft. A build like that is my idea of a "max effort daily driver". Cranking pressure on that engine was measured at 170psi, and dynamic compression calcs out at 7.88:1 using the wallace calculator. I would have no problem using a camshaft that size, since it worked so good in that build. But using that camshaft on a 9.5:1 engine results in a 8.22:1 dcr. I feel that's a bit too high. The 268 with the same static compression ratio spits out a 7.81:1 dynamic comp ratio. Second reason I chose this cam is because I expect it to work with my factory converter. Someone with way more experience can chime in on this, but I understand this cam will come on somewhere between 1500 and 2000 rpms. And regarding David Vizard's 128 rule, a 110 LSA is what it calls for in this application (318 with 2.02 valves and between 9.5-10.5 comp).
Nailed it! ^^^^^
Better research than blabbering fools
