TheMrAMack
New Member
Hi guys, new to the forum! Just posted my welcome post, but I have a technical question I can’t quite figure out.
My 71 Duster currently has a mild 360 in it.
After installing the motor, it will not idle. Have to keep it around 2500 rpm.
Running 31 degrees timing.
750cfm Holley stay carburetor.
The kicker is, when I shut the hood it gets worse… Will jump another 500 rpm or more.
The only thing I can think off is it might have a leak around the carburetor due to a bad gasket. Runs like a champ otherwise, no backfiring or anything.
Thoughts?
Thanks
-Andrew
Thoughts?
Thanks
-Andrew
