Manual steering pitman arm shaft seal
Mr Dart
Finland Europe
Can anyone tell me from where I can get pitman arm shaft oil seal for manual steering gearbox. Original part number 2127154. It seems to be very difficult to find.
eBay. Price seems ridiculous but it is available.
price for NOS would be higher but... source a shaft seal from a industrial supply company per the dimensions required should find it for less.
You could try contacting Firm Feel or Steer and Gear to buy one. I'd imagine they have an aftermarket equivalent sourced like Redfish says in post #3.
Many thanks to you all for your answers. But problem is that national seal 6859S is not correct. I have that seal. To be clear Steering gear is original -64 Dart manual steering. And sorry for talking millimetre measurements, I don't have inch gauges. Outer diameter of seal is 43 mm and housing for seal in steering gear has 39,35 mm diameter. Seal inner diameter is 29,55 mm (not pushed wide very gently measured) and pitman arm shaft diameter is 28,55 mm. See attached pictures.
Gates 351020 or Edelman 8715 I believe is what you are looking for.
Here is the Edelman part.
Seal Kit
divide metric by 25.4 to get inch. So your shaft diameter in metric of 28.55 divided by 25.4 gets you a 1.125 (1&1/8") shaft diameter.
SKF 11067 seal is close to your measurements. It can be difficult to get exact measurements on a used seal. Considering the low price , it might be worth a try.
