replicaracer43
Grumpy Old Man
- Joined
- Oct 10, 2008
- Messages
- 6,051
- Reaction score
- 7,867
Crower solid flat tappet, but was setup with a gear drive, with a thrust bearing behind the cam gear, and a thrust button in front. Unfortunately, it looks like they set the cam up to center the lobes under the lifters, which is also a no-no, and it had basically no lifter rotation. Allready had worn all the crown off 3 or 4 lifters, and lobes worn pretty significantly for the small amount of run time it saw. Going back with a solid roller this timethat crank... wowwww....
any idea on what the cam was?
