Dartswinger70
I had heard someone call the Poly a "318 Big Block"once... ![:thumbsup: :thumbsup: :thumbsup:](/mopar/styles/default/xenforo/smilies/ATT00014.gif)
Shows their ignorance....I had heard someone call the Poly a "318 Big Block"once...
Yeah, I wish they wouldn't use that term. The poly 318 block is no wider than any other small block. It's the heads that make the whole engine overall wider.Or "Wide Block"
You'd have to swap cranks or modify the (early) 273's crank flange to fit the later OD transmission- remember, all pre-'68 engines had the smaller register for the convertor snout.You could even make a 273 into a cheap MPFI engine by bolting on intake and beer-keg intake, and add the Magnum flex-plate w/ "toner ring". You cut a hole in the transmission bell-chamber to fit the crank sensor on a bracket (search photos). Could also bolt on a Magnum transmission, which gets overdrive, but must reform the trans tunnel for clearance.
I would imagine 920s or 302 Swirl Ports. Not sure J heads are allowed.What heads is he running to turn 10.30s?
There’s some things you can do to make the 273 a little screamer.Hey there,
Ive gone and done some reaserch and have read some articles about the 273 already but I am very intrested in what anyone who has owned or owns a car with a 273 in it has to say about them. What makes them diffrent from other mopar small blocks? What kind of issues do they have? I would love to hear any general information about them if your willing to share. I personally dont own one, but ive seen and worked on a lot of mopars but haven never seen or worked on a 273 so I am just genrally curious about them.
Thanks for reading.
Good thing about 273 is if you like rpm I don't take much to get a larger engine to spin takes serious head flow with 273 a mild prepped 360 head is all you need.There’s some things you can do to make the 273 a little screamer.
Just should not do it with a low compression 2bbl 273 or you will have a dog. and you must use a 340/360 head gasket or the fire ring will be in the chamber. Even lower compression....a 3 angle valve grind on a 360 head will make a lot more flow over a prepped 273 head, the 188 valve does fit, in the bores, last time i flow tested difference was bout 25 cfm per port.
