MidnightSwinger
Thank you!Making good progress![]()
Everything looks really clean and new. I wish I could find some identifiers on the pistons. All I could see was Made In USA and LY on the back of the piston, silvolite?looking from the bottom the pistons look pretty new![]()
Yeah not really lol, but at least it’s black like the rest of the interior now.that'll be a no then![]()
Edit; not better...easierThis just showed up! This is a part I have wanted to order from Mopar performance since I was a teenager. I know the newer kits are better because you don’t have to drill the frame, but I just like the old school stuff.
MOPAR BABY!!!Edit; not better...easier![]()
I'll tell you first hand too that the easy stuff usually doesn't end up that way either.MOPAR BABY!!!
Thanks man, sometimes I wonder if I should edit what I post and just post the major stuff. But building cars is all about a bunch of “little wins” adding up to the big picture. So I’ll post it all.That's cool, that thing is coming together. I get to take a week vacation this coming week with nice cool weather. I plan on making some serious progress on my junk dumpster.
What's really cool is theres not a lot of build threads going on, they're cool to follow along with
Post it all, because then you can go back and look (most importantly).Thanks man, sometimes I wonder if I should edit what I post and just post the major stuff. But building cars is all about a bunch of “little wins” adding up to the big picture. So I’ll post it all.
I’m stoked for you to make some progress on your race car. Get up early before it gets too hot and you lose motivation.
Get ‘er done and take some damn pictures!Post it all, because then you can go back and look (most importantly).
Yeah I think we have pants and long sleeve weather coming , well atleast comfortable for cutting, welding and stuff like that.
Hopefully I can get the hand of pipe notching quickly and not waste any steel from my cage.
Whatcha having the machine shop do ?Burning the midnight oil. Short block is disassembled and ready for the machine shop. New bearings throughout. Forged flat tops going in. My “free” 383 is adding up.
A real valve job on the speedmasters, and a resurface. I found some of the cam bearing material was chipped off the side of 2 cam bearings, so I’m just getting them replaced after a hot tank.Whatcha having the machine shop do ?
That’s my dilemma, to do it right I need to get the crank ground,rods resized and balance the rotating assembly.if you're buying bearings anyway i'd get the crank ground. you'll have the bores at least honed for the new pistons/rings, so it seems daft not to get the bottom end right just once.
neil.
Yeah, something went through the oil. My guess is whatever broke out of the intake bolt threads on those 906 heads probably didn't get cleaned out and happened after the build at some point.
