mshred
The Green Manalishi
- Joined
- May 2, 2008
- Messages
- 3,310
- Reaction score
- 177
I have a pushrod length checking tool, but pushrods are just one more thing to buy, so if I dont HAVE to, I'd like to try not too. Then again, I can always throw the tool in and just see, for purposes of not being a hack lolYou might be able to use stock pushrods but you'd be better off measuring with a checking pushrod once the heads are on with head gaskets and getting a new set, old factory pushrods often have some variation in length which can do weird stuff at higher RPM.
Ill take the "bait"- Its not overkill at all lol...that's a very OLD mentality to have with converter technology coming as far as it has. Your logic makes perfect sense, and hence why I want a converter that will get me up to peak torque quick, and when I shift the rpm drop should still keep me there.Just curious, Why is it killing it?
I get it’s a little much for this level of build, but even a fairly stock 360 gonna make peak tq around the 3000-3500 rpm stall especially with a cam.
Yea, I thought it was pretty obvious from what I listed in my original post that im not looking to put it in drive and cruise to the local bingo night like some old fogie. I want my cruiser (or i guess correct term would be hot rod) to have some balls and be fun to drive. Ive driven with 5500 stall converters on the street and never had an issue, in fact I loved it, so I know a 3000 stall would work well for this combo.I can't get into the op's head as far as his tolerance for a ''mostly street'' heavy car. The converter preference and MVB leads me to believe he's looking for more of a hotrod type ride then some of us realize. I've built a few like that myself, but others i've done with good low end torque, a modest gear like a 3.23, and a aggressive timing curve with a lower stall turned into a great stoplight to stoplight beast and i never missed having to jump on the revs every time i wanted to accelerate a little heavy. Just a real nice pull up through the rpm range.
Going to see what my converter does with the combo in front of it and then i will go from there on converter choice, but I know it will most likely end up there (3000) and like it
