A833 rear seal & bushing removal/installation
French demon
South of France
Hello guys
What's the easier and better way to remove and install the yoke seal on a A833 without the Mopar special tools?
:thankyou:
François
You WILL need the special tool for the bushing install. I took mine to someone who had the tool.
Brewer's Performance - Mopar A833 4-Speed Transmission and Component Specialists
Pull the tail shaft housing, take it to a shop that has the proper sized drivers, and have them pressed in and out. Quick job and pretty straight forward.
Thank you very much guys, but now I realize that the tail shaft housing has to be removed from the main case.... :eek:
Is it possible to remove the tail shaft housing without the mainshaft coming with it?
I'm a total newbie in transmissions and dismanteling the gearbox in two exceeds my meager skills.
I think that I will only replace the tailshaft seal :rolleyes:
No, tail shaft housing will NOT unbolt and slide off the back. You have to remove the side cover assy & forks, then remove the mainshaft/tailshaft as an assembly.
Hello guys
:thankyou:
François
Run over to MyMopar.com and download a copy of the service manual, they are free. Some of them over there got there because of the guys right here
Some of them, you have to settle for a year ahead or behind, or Plymouth/ vs Dodge, etc. So check both listings.
Thanks Dan. Very useful to have the opinion of a specialist
I’m not going to embark on such a complex job.
Next week, I will order some parts from you. I'm preparing my list... ;)
Hi.
Of course, I've already downloaded the FSM and I saw removing the tailshaft housing involves the complete disassembly of the gearbox :BangHead:
you dont need to disassemble the tranny, crack the bushing with a small screwdriver, then take a bigger one and open the "puzzle" line. See the fine atop the blue line.
