Amazon product ASIN B01MY4T4BUTo what part number? Thanks
Yup!I too ran into that issue. Had to put the OE style brake light bulbs back in for the turn signals to work when the headlights were on. This is even using a LED turn signal flasher with the correct black ground wire. Wierd.
Thanks, but................"load resistor may be required"......??
We will see!I too ran into that issue. Had to put the OE style brake light bulbs back in for the turn signals to work when the headlights were on. This is even using a LED turn signal flasher with the correct black ground wire. Wierd.
The front turn sisgnal are just fine once I cleaned them up as posted.Sounds like some basic tests might be useful to solve your problems.
1. Do your bulbs light up if you short across the two flasher terminals with the turn signals on? Is they do, your flasher is likely bad or hooked up wrong.
2. Can you hook up your flasher and a bulb in series directly across the battery to see if it flashes?
A lot of chinesium stuff is bad out of the box. Divide and conquer. Check all your parts first to see if they are good.
It is also possible that the two flasher wires are reversed in the flasher connector.
I too prefer the OEM coke bottle green illumination produced by incandescent lights behind blue diffusers. I don't think a poll in this forum could prove which side (OEM or LED), is the minority since not every classic car owner, or even all a-body owners participate and/or would respond to the poll.i guess i'm in the minority in that i like the soft incandescent glow of the stock setup.
Ok, let’s do a little math on load resistors.Superbright LEDs is suggesting trying "load resistors".
Will try those after I get the Barracuda back.
She's at the shop overnight straighteneing out a few issues, which I will post on another thread.
Wow!Ok, let’s do a little math on load resistors.
1157 bulb (rear) brake light is 2 amps.
1034 bulb (front) is 1.8 amps.
Led bulbs pull about 0.2 amps
So 2 + 1.8 = 3.8 amps through the flasher.
The led bulbs pull 2 x 0.2 = 0.4 amps
So you need a load resistor that pulls the difference, which is 3.4 amps.
14V divided 3.4A = 3.5 ohm load resistor to pull the same current with the turn signals on.
14V x 3.4A = 47 watts that the load resistor will need to dissipate.
47 watts is a lot of heat. It will take a 100 watt resistor to run safely at 1/2 capacity.
A 100 watt resistor is large and will put off a lot of heat.
My point is that the load resistor is a very brute force method of solving the problem. It also negates one of the best features of the led bulb, that is running on less power.
If you have healthy wiring and the right flasher that is connected properly, your LEDs should work great.
Will definately "report in"!Two six ohm load equalizers in parallel is 3 ohms. This is even resistance less than my estimated 3.5 Ohms. Heat generation might not be a big problem as most folks probably won’t have the brake lights or turn signals on for that long. It will be interesting to see how they work When you try it.
I did the white overlay on the stock face and LED’s. 71Duster Came out greatI am going to use gauge face overlaps in white when I replace the dash bezel; as well as upgrade to LEDs.
I have used LEDs in the past to get better Illumunation. But, I have not disassembled the 67 Barracuda dash yet.
The gauge face overlay folks I am considering say to simply use their overlays over top of the OEM faces! i.e., you don't have to remove the OEM faces!
But, if the gauge face lighting is coming from behind the faces, that would be cutting down on the transmitted light.
So, my question is....with the 67 Barracuda gauge faces, is the light coming from the periphery of the gauges (from the sides); or from behind?
This relates to some of the past posts on this Forum about whether the LEDs should have diodes all facing forward; or some diodes on the sides of the LED, scattering the light.
What's the difference between the turn signal flasher and the hazard flasher?Taillights work much better with LEDs for me. Much brighter!
I bought the LEDs on Amazon. I just picked some high rated ones. They weren’t that expensive.
I left the front turn signal’s incandescent so my flasher still worked. Get a flasher designed for LED lights if you are having issues. LED flashers often require a ground to work, so don’t forget that. Load resistors are a very crude way to solve the flasher issue.
Don‘t forget to change the emergency flasher too.
I’ve been playing with LED’s and home lighting for the past couple years. Seems I am now the go to guy in my area when someone wants them, probably just for a lack of any competition.If I need to improve my home lighting...yes!
On a car...NO!
They are the same part.What's the difference between the turn signal flasher and the hazard flasher?
The OEM ones are rectangular boxes, not like the round Tridon replacements.They are the same part.
Looks like you were LED astray!I’ve been playing with LED’s and home lighting for the past couple years. Seems I am now the go to guy in my area when someone wants them, probably just for a lack of any competition.
That's what I'm after.I did the white overlay on the stock face and LED’s. 71Duster Came out great
Yes. Yes, I was……Looks like you were LED astray!
Exacerbated by the fact you can't even get decent 1157 bulbs anymore.Yup!
There's a lot of talk on the web about needing load resistors on the taillights.
Polarity should not be an issue with Superbrightleds. But, load resistance might be.
There are several past threads, even here on FABO about no real good direct replacements for the taillights and turnsignals.
I am willing to keep the front turn signal incandescent; no problem.
When I piddled around today, I went ahead and disassembled them, cleaning the lens and chrome bezels.
The reflectors are toast! I could not clean them up., being badly oxidized.
So, off again to the store for some chrome spray, before I reassemble them.
I emailed Superbrightleds, and will await their recmmendations on the tail/brake lights.
One of the historic thraeds recommended a Sylvania bulb that would work - but is no longer available.
