67FormulaS_273HiPo_4spd
I'm freshening up a 1974 low comp 318 with a quick hone, new plasma moly rings and new bearings. I done some home bowl porting & port matched the 675 heads with larger 1.88 / 1.60 valves. SCR will be around 8.5:1 with Mr Gasket 1121G (0.028") head gaskets. Using a port matched Performer intake, 650cfm AVS2 carb, Prestolite dual point distributor, and 1-5/8" Dougs headers. It'll be going into a 67 fastback, 4-speed Barracuda, with an 8-3/4" 3.23 geared rear. I just want it to sound cool, turn the wheels and run nice on the street.
I have a new Crane Cams Z-268-2 flat tappet hydraulic stick that I was thinking of using, has anyone run one of these in a similar combo with good or bad results?
CRANE Z-268-2
Advertised duration 268 / 276
Duration @ 0.050 212 / 220
Lift 0.459" / 0.480"
LSA 112
RPM Range 1200 - 5000
CRANE Z-268-2
LSA 112
